SolaraGuy.com • View topic - Should i keep my stock shocks
Postby DvS One » Sun Apr 20, 2003 9:40 pm
Is it okay for me to keep my stock shocks on when i put my eibach pro kit springs?
DvS One
Regular SolaraGuy
Regular SolaraGuy
Postby 99solarai4 » Sun Apr 20, 2003 9:42 pm
the stock ones r crap. save up til u can afford to get the tokicos.
'99 Solara SE i-4
Back to Stock
99solarai4
Postby Mole » Sun Apr 20, 2003 9:44 pm
that is recommended, but what mileage do you have on the car? i was running my stock struts from 17k up to 30k till the stocks went out. pretty fun though, when on fwys im a floating boat after going through an imperfection on the road.
Postby DvS One » Sun Apr 20, 2003 9:47 pm
Im about to hit 47k my car is a 99
DvS One
Regular SolaraGuy
Regular SolaraGuy
Postby krook » Sun Apr 20, 2003 9:55 pm
why don't you just swap the struts and the springs out at the same time? are you gonna DIY? you'll save money either way if you get struts/springs done all at once. if you lower it with the springs, you'll have to get a re-alignment check done. and if you get the struts later on, you'll have to get that same check done again and pay the same fee.
besides, with upgraded springs, you'll wear out you're struts more faster. might as well do it right the first time.
krook
Re: Should i keep my stock shocks
Postby Flipside909 » Mon Apr 21, 2003 12:19 am
DvS One wrote:Is it okay for me to keep my stock shocks on when i put my eibach pro kit springs?
Not really because your ride will get bouncy and uncomfortable in no time.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby xXsolaraXx » Mon Apr 21, 2003 12:54 am
i made the mistake of upgrading to eibach and leaving my stock struts on...it actually created a leak in the strut after about 2000 miles...so i recommend doing the upgrade with the springs at the same time...L8r moe :evilbat:
xXsolaraXx
Postby Yanks0114 » Mon Apr 21, 2003 8:20 am
Do it right the first time, especially if you are paying someone to do it. For the price the springs/struts are at, it doesn't make sense to have to replace the struts later on. You won't regret the upgraded suspension.
The OEM struts will last about 6 months until they are going to show signs of going bad
Postby Mole » Mon Apr 21, 2003 9:19 am
yup, i reccomend the same advice, esp with the mileage you are at. unless you like the hardcore body roll and boat feeling 8)
Thanks for the advice.
Postby DvS One » Tue Apr 22, 2003 7:56 pm
Thank you guyz for your advice...so i guess im gonna postpone my installation until i buy struts.
Minh
P.S. How much does tokicos run for my car?
DvS One
Regular SolaraGuy
Regular SolaraGuy
Re: Thanks for the advice.
Postby Yanks0114 » Tue Apr 22, 2003 10:04 pm
The tokico struts are $329 for the solara. Check the sticky message in the forsale section for info on how to purchase them
