SolaraGuy.com • View topic - Air/Fuel Gauge
Air/Fuel Gauge
Air/Fuel Gauge
Postby Dawgz » Wed Jul 04, 2007 2:53 am
ok so i was looking on ebay and i came across this...
http://cgi.ebay.com/ebaymotors/Megan-52 ... enameZWDVW
i thought it would be good to have, is this what i want to use? what does it hook up to? Is there something better along the same price?
is it worth getting?
Postby DatSRBoi » Wed Jul 04, 2007 8:38 pm
Uhh thats for show only.. If you depend on that to tune your car..... Good luck puahahahha.. It will KAABOOM your car with that thing. The real one is like 250 to 600 dollar for the all out one. Cheap ones like that is for show.
Postby Eye8Pussies » Wed Jul 04, 2007 10:07 pm
it works and will tell you if there are problems with your car
but for actual tuning, you'll need a wideband
Postby woa_its_j3ff » Wed Jul 04, 2007 10:15 pm
Eye8Pussies wrote:it works and will tell you if there are problems with your car
sorry to threadjack but how will that tell you if there are probs?
i have the narrow brand and all it does is sweep.. sometimes itll stay on either lean or rich but that's only when I just start the car and that lasts just for a few seconds or so... before starting the sweeping motion (when air is gettin sucked in or when my foot is on the gas)
Postby Dawgz » Wed Jul 04, 2007 10:54 pm
i only tune @ the dyno with their equip, i want a gauge that will tell me for saftey reasons...so is that one okay?
Postby DatSRBoi » Thu Jul 05, 2007 2:18 am
Dawgz wrote:i only tune @ the dyno with their equip, i want a gauge that will tell me for saftey reasons...so is that one okay?
Postby Dawgz » Thu Jul 05, 2007 9:39 am
I think you may not be reading english correctly these days, i said to you that if i need to tune, i go to the DYNO and have them tune it for me with their equipment (their wideband and wat not), i wanted to use a gauge for daily driving and to use it as a precaution for any early symptoms.
U say its for show, im asking is it okay to depend on for early symptoms
I said nothing about Tuneing.
Postby Sentinel » Thu Jul 05, 2007 9:49 am
What does it hook up to? does it have a sensor somewhere or does it just piggyback to the ECU?
I would think that your CEL system would be a decent warning for running too lean and blowing stuff up, unless you have screwed with it.
Sentinel
Postby indiglosolara » Thu Jul 05, 2007 11:08 am
I am going to have to back Dat up on this. The narrow band A/F Gauge does NOTHING!!! Even to use it as a precuation.. IT DOES NOT show accurate information since all it does is bounce around. Its for SHOW purposes. If its not reading correctly its not going to sell you anything.
I had one in the solara before and it was far from accurate. If you want a A/F gauge I would fork out the money and buy the Wide Band. Even if its not for tuning its more accurate to read and you will be able to tell if you are having problems.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Dawgz » Thu Jul 05, 2007 11:55 am
Okay, thats all i needed to know.
Thanx to all.
Postby Eye8Pussies » Thu Jul 05, 2007 1:17 pm
well, coming from a guy who has both had a narrowband gauge and now has a wideband gauge....
it does work by giving you an idea.
It WILL tell you if you are running rich, and it WILL tell you when you are running lean.
When people say that it does nothing because it continuously sweeps, it's doing that because there is NOTHING WRONG.
Unless you have had things go wrong with your car- i.e. install new REAL performance parts yourself, etc. it will only ever sweep and be useless for tuning.
I have had mine show all green....much too often. So I got a wideband....and guess what- I was running an AFR of 10.
I've had mine show nothing at all....guess what...then I popped a code for a lean front bank. My car was running so lean that it was out of range.
So unless somebody here has owned both a narrowband and a wideband, you have no idea what you're talking about.
All wideband owners always say that narrowbands are useless since they have the "real" thing. But since I've had both and now have a wideband, I still don't knock the narrowband for doing what it's designed for, which is different from a wideband.
Postby Dawgz » Thu Jul 05, 2007 1:21 pm
Cool, thanx!
