SolaraGuy.com • View topic - jpp y-pipe questions
Postby TMMK Toy » Wed Jul 04, 2007 7:35 pm
So I'm thinking of buying a used older JPP y-pipe from someone I talked to recently. He told me he doesnt have it on his car as he was throwing a cel with it on, but he attributed it most likely to the high flow cat on there. This is the style I guess that they used to make that could be purchased separeately. I'm really thinking of getting it and just putting my factory cat on in the high flow one's spot, as from what I've read on here the real restriction is in the pipe and not the cat. What are people's opinions of this and with a regular cat will the likelihood of a cel decrease? He said it caused him to run pretty rich.
I also thought of maybe leaving the high flow unit on and finding a way to fool the o2 sensor but not totally sure how. I heard of URD selling a kit for that but no longer see any listings of such a product. What should I do?
My flex section leak is really annoying me and this pipe would be the best solution for me provided it wont give me tons of problems if theres a proper way to install it.
TMMK Toy
Postby kwyse » Wed Jul 04, 2007 10:23 pm
Leave the high flow cat on...URD sells an O2 simulator for like $60 (last time I checked) and it seems like a real easy hook up.
kwyse
Postby Akfahad » Thu Jul 05, 2007 8:48 am
leave the high flow cat on there, buy the 02 sim from URD (that's where I got mine) and it's just a matter of splicing the wires at the ECU for the connection. It actually took my 02 simulator a while to kick in before it eliminated the CEL, it wasn't immediate, which is what I thought it would do. So if you do go that route, don't freak out that it doesn't work right away.
And yes, buy the pipe.
Postby Dawgz » Thu Jul 05, 2007 9:40 am
Will the high flow cat pass emissions?
Postby Astro » Thu Jul 05, 2007 10:27 am
It should, but barely. I recently went and would've passed if it wasn't for the cat being gutted.... :lol:
Postby Akfahad » Thu Jul 05, 2007 1:16 pm
Dawgz wrote:Will the high flow cat pass emissions?
yes...as long as you have some kind of catalytic
Postby TMMK Toy » Thu Jul 05, 2007 7:19 pm
No emissions tests here :)
TMMK Toy
Postby SleeperSolara » Thu Jul 05, 2007 8:46 pm
Shoot you can still have a high-flow cat, and wit a spark plug thingy from autozone, your car won't throw a CEL......
Postby Midias » Fri Jul 06, 2007 11:14 am
SleeperSolara wrote:Shoot you can still have a high-flow cat, and wit a spark plug thingy from autozone, your car won't throw a CEL......
Yea I told a gen 2 I4 to do this worked great. Get 18mm anti-fowlers from the HELP section of auto zone, advance auto, ect. drill a 1/2 inch hole in 1 only 1 then thread the O2 sensor into the drilled anti fowler. Connect the two anti-fowlers and screw them back into the car.
Postby 808Camry » Fri Jul 06, 2007 11:39 am
Akfahad wrote:leave the high flow cat on there, buy the 02 sim from URD (that's where I got mine) and it's just a matter of splicing the wires at the ECU for the connection. It actually took my 02 simulator a while to kick in before it eliminated the CEL, it wasn't immediate, which is what I thought it would do. So if you do go that route, don't freak out that it doesn't work right away.
You actually need to hookup an OBDII Scan tool to it to clear the code. If you don't have one it will clear on its own after so many engine starts when the problem is no longer existent.
808Camry
Postby Dawgz » Thu Jul 12, 2007 7:58 pm
Does the JPP ypipe bolt up to the stock header?
Postby Midias » Thu Jul 12, 2007 8:18 pm
Dawgz wrote:Does the JPP ypipe bolt up to the stock header?
Yes
Postby TMMK Toy » Fri Jul 13, 2007 11:14 pm
Got the pipe and hoping to install once the simulator arrives. I guess the gaskest for these flanges are just the doughnut variety and nothing more?
TMMK Toy
Postby Midias » Sat Jul 14, 2007 6:00 am
TMMK Toy wrote:Got the pipe and hoping to install once the simulator arrives. I guess the gaskest for these flanges are just the doughnut variety and nothing more?
Probably that is stock otherwise you can use FEL-PRO part number 60674 catalytic converter gasket for mercury villager v6 183 for the part betweent he stock manifolds and the Y pipe
