SolaraGuy.com • View topic - im going to cry
im going to cry
im going to cry
Postby redgen1 » Thu Jul 26, 2007 5:26 pm
ive waited a year and a half to finally get new tires for my rims.. and come to find that 235/45/17s dont fit on a gen 1.5 rear axle... anyone know where i can get spacers and for how much..? :cry:
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby solaraN8 » Thu Jul 26, 2007 5:42 pm
its not the tires that are at fault its you buying the wrong offset wheels :-) they wont let you just return the tires that you baught and pick up some 225/45's
New Car, 2003 IS300 5mt
solaraN8
Postby YESCA » Thu Jul 26, 2007 7:36 pm
Weird I have 18x8.5 inch wheels with a 35mm offstt and I'm running 225/40/18. I get a little rubbing but not much(need to roll the fenders) I believe there is someone on the board running 19x8.5 with 235/45/19 and he dose not have a problem. What is the offset of your wheels? if you have rubbing issues, invest in rolling the fenders, then you should be straight.
YESCA
Postby redgen1 » Fri Jul 27, 2007 9:36 am
they fit on the front fine, they hit the strut tower in the rear, nothin near the fender. I assumed they would fit because they came off an 04 SE my friend has... as for getting like 225/45/17, they wouldnt fit on the wheels... not properly anyways
02 SLE V6
redgen1
Postby redgen1 » Fri Jul 27, 2007 10:13 am
so im thinking if i find a 10 mm spacer this should take care of the problem, at lesat if i just put them on the rears..? is my train of thought correct? since a 225 will fit without isse, but a 235 wont?
02 SLE V6
redgen1
Postby redgen1 » Fri Jul 27, 2007 10:17 am
02 SLE V6
redgen1
Postby redgen1 » Fri Jul 27, 2007 10:26 am
with hub centric rings too i suppose..
02 SLE V6
redgen1
Postby Midias » Fri Jul 27, 2007 11:49 am
There are spacers out there with hubs already in them but what every you do use longer studs.
Something like this http://cgi.ebay.com/ebaymotors/15MM-Whe ... enameZWDVW
no ring should be needed.
Postby redgen1 » Fri Jul 27, 2007 10:32 pm
k - then only thing i have left to ask is - is my logic that a 10 mm spacer should be enough? because im not trying to have the back wheels offset any further then necessary.. i dont want my car to look like it just hopped the border.
02 SLE V6
redgen1
02 SLE V6
redgen1
Postby CASTRO » Sat Jul 28, 2007 1:34 am
solaras have more clearance than my camry. I am currently using H&R 15mm spacers in the rear with no issues. You might consider those as 5mm spacers rub/touch with tires that have soft sidewalls during turns. 10mm would be a little too perfect to the point that It wont make me worry, but it will remain at the back of my mind. I say go 15mm and do it right.
CASTRO
Postby redgen1 » Sat Jul 28, 2007 5:24 am
castro that was exactly what i was looking for, thanks man. problem solved for now, ill put pics up when i finally get them on
02 SLE V6
redgen1
