SolaraGuy.com • View topic - O2 simulator install
Postby Dawgz » Fri Jul 27, 2007 9:16 am
Can anyone post up the diagrams or the pin's to where i hook the o2 simulator up to? I have absolutely no clue where to begin.
all i know is that i gotta do it at the ECU pin's....correct?
Postby SC V6 » Fri Jul 27, 2007 9:20 am
depends on the brand you get
SC V6
Postby Dawgz » Fri Jul 27, 2007 11:36 am
i was told its a URD o2 simulator
Postby TMMK Toy » Fri Jul 27, 2007 10:43 pm
Told ya man, you order it from URD and they will inc. directions
TMMK Toy
Postby RDKamikaze » Sat Jul 28, 2007 12:13 am
I have a mechanical o2 simulator that was dirt cheap. It only requires some drilling, but it works great! I got the parts for under $5 at AutoZone, and drilling the holes isn't hard at all. I tried an electronic o2 sim, but it always threw a code at higher RPMs.
http://www.civicforums.com/forums/79-fo ... lator.html
RDKamikaze
Postby Dawgz » Sat Jul 28, 2007 7:02 pm
i see the DIY, its a nice write up, but how does that even work? how does it trick the o2 sensor?
Postby RDKamikaze » Sat Jul 28, 2007 7:18 pm
I wondered the same exact question before I did my o2 sim. All I know is that it works. Some people said it has something to do with putting the o2 sensor back far enough to where it doesn't read too hot or high, so it sees the system running "normal." Like I said, I'm not positive, but I know it works. I've only had the CEL come up once, and that was today. I went on a 2 hour road trip this morning in pouring rain the whole way up hills and stuff. It was the first and only time it came on, but a quick battery disconnect and reconnect fixed the whole problem.
RDKamikaze
Postby Dawgz » Sat Jul 28, 2007 7:22 pm
ill do the o2 simulator, and if i cant get that to work, ill do this trick.
Thank you very much for posting this link so i can look back onto it (as well as others) if i need to use it.
Postby RDKamikaze » Sat Jul 28, 2007 7:24 pm
No problem! I highly reccomend starting with this simple mod, though. I still have my electric o2 sim somewhere around the house, and I haven't gotten into selling it. Good luck with your car, bro!
RDKamikaze
