SolaraGuy.com • View topic - ebay exhaust
ebay exhaust
ebay exhaust
Postby yevhend52 » Fri Aug 10, 2007 10:16 am
2000 SLE V6
yevhend52
Postby Chinky420 » Fri Aug 10, 2007 10:19 am
for that price, you should grab it, and do a before/after dyno on it, and let the rest of us know how it goes :-)
Chinky420
Postby ThatVietGuy » Fri Aug 10, 2007 10:31 am
Don't do it: cheap design and adds nothing to the car.
ThatVietGuy
Postby unbalancedwood » Fri Aug 10, 2007 10:36 am
"Ebay Headers" have been proven no added benefits besides the NEW look....
unbalancedwood
Postby Dawgz » Fri Aug 10, 2007 10:43 am
unbalancedwood wrote:"Ebay Headers" have been proven no added benefits besides the NEW look....
where did u quote this statement from?
Postby DatSRBoi » Fri Aug 10, 2007 11:20 am
It does give power gains. The only problem with the gain is you will loose efficiency because the way the headers are design its will put more stress on your transmission because the engine may flow better, but now its loosing the tq band. The design also follows the theory too much where they try to equal lenth everything. But when you over size your headers and pipes, you need to give more power somewhere else to retain that push and pull on the exhaust system or else it will just cause uneven flow on an oversized pipe.
Ill find the thread later on why oversized pipes on a NA car=Bad on engine and tranny.
Postby yevhend52 » Fri Aug 10, 2007 12:52 pm
So you all agree that its a bad design right?
Idont know much about exhausts, but i was just browsing on ebay and saw this and had to ask.
Thanks for the replies
***Dats if you can find me that post I would apreciate it. I'm curious to see what it sais.
2000 SLE V6
yevhend52
Postby Dawgz » Fri Aug 10, 2007 1:13 pm
DatSRBoi wrote:It does give power gains. The only problem with the gain is you will loose efficiency because the way the headers are design its will put more stress on your transmission because the engine may flow better, but now its loosing the tq band. The design also follows the theory too much where they try to equal lenth everything. But when you over size your headers and pipes, you need to give more power somewhere else to retain that push and pull on the exhaust system or else it will just cause uneven flow on an oversized pipe.
but wat about a Supercharged Solara?
Postby TMMK Toy » Sat Aug 11, 2007 8:04 am
Why would just headers put strain on your tranny? If from just adding power then ya, but then all mods are shortening tranny/engine life to some extent
TMMK Toy
Users browsing this forum: Google [Bot] and 53 guests
