SolaraGuy.com • View topic - Dat's ypipe and Stock headers
Postby Dawgz » Fri Aug 17, 2007 8:04 pm
So as u know, i bought a really fckt up dat's ypipe, which turned out to much to fix and be worth it. So i had a really nice SG member help me out Cisco (facevedo17) who i met up with around my area and sold me his untouched dat's ypipe. I took the ypipe to Applied Force, its a fabrication shop up in boonton which does extremly nice work. I had them fix my ypipe and also sand my header's flange @ 10,000ths of an inch to get rid of the Rust and caked on crap on the headers and the o2 bungs and the egr fittment. Also, this Fab shop does Heliarc welding, the strongest welding u can get. Long story short, here are the pics, they will be installed comming next week and then if i get them installed by wednesday or watever, i can take the car to the dyno this week as well.
Postby Somedude » Fri Aug 17, 2007 8:06 pm
cool.
Somedude
Postby Dawgz » Tue Aug 28, 2007 10:39 pm
SO everything is finally installed and what not, it was a pain getting all this done, alot of stuff didnt align perfectly, these are all the pics i took, they pretty much explain themselvs.
Here are some of the problems we faced...
1) The A/F Sensor on the rear header was fused on the old header, and while taking it off, the thread on the sensor stripped so i need to replace that...($225)
2) The rear Flange was off by 1/4 to 1/2 of an Inch and didnt let us bolt it up. (needed to be fixed by cutting the flange off, and then aligning it and then welding...
3) the front flange had a gap when everything was bolted up, this was also completed along with the second flange so it all worked, the fix for this was sanding the flange down a bit...just a tad bit, now theres no gap.
4) the flexpipe, after the cat was installed had a height issue that didnt allow it to mate with the Mid pipe, fixing the Rear flange and the front one solved this issue.
Postby Dawgz » Tue Aug 28, 2007 10:48 pm
o, and that power drop after 4k, is no longer there, the car pulls thru the whole band, its sweeeeeeeeeeeeeeeeeeeeeeeeeeet.
Lets just hope its not my imagination, Dyno Day is setup for Friday.
Postby Eye8Pussies » Tue Aug 28, 2007 11:53 pm
let us know how it goes, man...
Postby Dawgz » Wed Aug 29, 2007 12:22 am
will do.
Postby Midias » Wed Aug 29, 2007 4:28 am
Glad to hear it pulls nice now and it all finally fit together nicely. Looks like 12.5 inches was jut about the right length for that cat.
Postby Dawgz » Wed Aug 29, 2007 9:16 am
yea, that was a nice fit.
Postby ---CAMRAZY--- » Wed Aug 29, 2007 10:36 am
Man, dawgs.... You have spent a lot just get piped.
Let us know how it goes!!!
Postby Dawgz » Wed Aug 29, 2007 10:40 am
^ yea i know meng, but what can ya do.
I feel a major diffrence for sure tho, the pre-cats were just no good.
Can anyone correct me if im wrong, but am i the only one on the boards that has a cali spec car with a Supercharger and converted it to Non-Cali spec headers and wat not? Cause i dont see any threads that mention ANyone with a pre-cat system that is boosted.
Postby Americanctm10 » Wed Aug 29, 2007 10:49 am
I know you went through hell and back to get this done, you should be proud. I can't wait to see the dyno results!
Americanctm10
Postby facevedo17 » Wed Aug 29, 2007 4:25 pm
Nice pics Yeah I bet it was a pain in the donkey ...but def payed off enjoyed by the way can't make it this Friday ....
facevedo17
Postby Dawgz » Wed Aug 29, 2007 7:38 pm
facevedo17 wrote:Nice pics Yeah I bet it was a pain in the donkey ...but def payed off enjoyed by the way can't make it this Friday ....
all good
Postby Dawgz » Wed Aug 29, 2007 8:28 pm
Here are pics of the Pre-cats, one on the Front header and one on the Rear Header's connection on the ypipe itself.
Here is the Rear header, no precat on the actual header, yet its still just a TAD bit diffrent than the non-cali spec header and needed to be swapped out...
The most obvious, the front header with its pre-cat...
Check out the material inside the pre-cat, i bet if u took all that b.s material, squashed it all to one side, u'd have, at max, 1/2 of the air flow of the non-pre cat headers, but i think it might be less!
Postby bassthrive » Wed Aug 29, 2007 9:45 pm
your dedication (time-wise and financially) is admirable. glad you finally got everything banged out!
what i want to know is what did you do for each of the sensors? are you running an O2 simulator? does the ecu "realize" you dont have precats anymore and throw a code, thinking it is polluting too much?
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
