SolaraGuy.com • View topic - Magnecor vs. NGK
Magnecor vs. NGK
Magnecor vs. NGK
Postby Guest » Wed Apr 30, 2003 6:52 pm
I've got a question, I have NGK blue wires brand new, and have an SC waiting for install. Would the NGK be as good as the Magnecor wires? Or would it be better just to go with Magnecor becuase its been the most popular choice?
Guest
Postby Yanks0114 » Wed Apr 30, 2003 7:20 pm
Just because it is most popular doesn't mean its the best. The main reason everyone uses the magnecors is because they were around first. The NGKs only came out recently.
The magnecors do provide a larger wire (8.5MM) but that may be unnecessary. Essentially the wires are for peace of mind and partially as an insurance policy when upgrading pulleys but the stock toyota wires are pretty good. For the money you can't beat the NGKs but you could always spend a few bucks more and get the magnecors
Postby krook » Wed Apr 30, 2003 11:05 pm
those NGK's should do just fine. yanks got the magnacore wires, and they're doing okay too. me personally, i have the NGK's...i think NASTY said the magnacore's thickness was a little TOO much insurance.
never hurts to be over-safe though! :wink:
krook
Postby Turbosolara » Wed Apr 30, 2003 11:51 pm
I hear plasma booster from ignition solution works very well and it worth it for perfromance and realiable.
Postby 808Camry » Thu May 01, 2003 2:53 am
Hey guys taht was me
Yea I'm gonna get the plasma booster as well. Still unsure of the NGKs I'd rather be too safe than jsut enough... ahh
808Camry
Postby Flipside909 » Thu May 01, 2003 10:12 am
Your OEM Densos will work just fine.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby 808Camry » Thu May 01, 2003 11:14 am
Even with the plasma booster Ryan?
808Camry
Postby Yanks0114 » Thu May 01, 2003 6:13 pm
Flipside909 wrote:Your OEM Densos will work just fine.
Yes they will work but as per your advice and many other people for extra insurance you should get upgraded wires. I personally agree that the stock wires are fine but with the plasma booster i'd say get the upgraded wires
Postby SC V6 » Fri May 02, 2003 5:18 am
where would be the best place to order a plasma booster?
and how much is an average price?
Also where is the best place to order the KV85 Magnecore Wires?
thanks
SC V6
Postby Flipside909 » Fri May 02, 2003 7:45 am
808Camry wrote:Even with the plasma booster Ryan?
Yup.
To get the plasma booster talk to Noel Ancheta at Ignition Solutions. www.ignitionsolutions.com
For Magnacors...contact Sander at The Wheel Supply. He's supplied the most Magnacor KV85 wires for the Camry/Solara platform ever. www.thewheelsupply.com
www.clublexus.com
Flipside909
Postby krook » Fri May 02, 2003 11:09 am
what does the plasma booster do?
krook
Postby Flipside909 » Fri May 02, 2003 2:51 pm
krooked Solara wrote:what does the plasma booster do?
Ensures a better and more consistent spark.
www.clublexus.com
Flipside909
Postby bimmer » Sat May 03, 2003 7:17 pm
so would that just insure efficiency or will it give gains?
ive read about those before in a magazine but it was a while back
NATO - No Altezza Tailight Organization
bimmer
Postby 808Camry » Sun May 04, 2003 12:45 am
It's more for efficiency. In my case assurance.
808Camry
Postby Flipside909 » Sun May 04, 2003 1:20 am
bimmer wrote:so would that just insure efficiency or will it give gains?
No gains. Only gain you get is piece of mind for efficiency.
www.clublexus.com
Flipside909
