SolaraGuy.com • View topic - Wheel Purchase Question-Please Help!
Postby Screwdriver » Thu May 01, 2003 6:17 pm
Hi,
I'm Seriously looking at a set of 17 X 8 rims with a 37mm Offset. They are the correct lug pattern. They come with Tires which are 225/45 R 17. I plan on lowering the car with the Tokico/Eibach setup shortly.
Will they fit?
Thanks in Advance for the help!
Aviv
Screwdriver
CORRECTION
Postby Screwdriver » Thu May 01, 2003 6:19 pm
Sorry. They are 225/55 R 17 Tyres.
Thanks.
Screwdriver
Postby Mole » Thu May 01, 2003 6:22 pm
what type of rims? with that offset, you might stick out a tad, but should fit with no problem. and you might have to roll or shave the rear fenders.
Postby happy_aggies » Thu May 01, 2003 6:26 pm
It should be. double check w/ discount tire. Call them up and says what ur suspension, wheels and tires.
happy_aggies
Postby Screwdriver » Thu May 01, 2003 6:36 pm
They are OZ Racing Opera 2 Piece Rims.
The 55 Profile on the Tire is what has me worried. Im not sure if the Eibach setup will let them fit.
Anyone with a similar setup?
Thanks guys
Screwdriver
Postby Flipside909 » Thu May 01, 2003 6:39 pm
Aviv, 17x8 with a +37 offset? I don't even think that will clear your fenders even with rolling. And you want 225/55R17 tires? You got the wrong wheels and tires for your Solara if you plan to lower it. :roll:
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby cdssolara » Fri May 02, 2003 1:30 am
Aviv - I left you a response on Camryman on this same issue. You are definitely going to have a problem with this size. The rim width, offset, and tire diameter would each create the possibility of rubbing on a lowered car. Put them all together, and there is no doubt that you will have to do some serious fender rolling or shaving. If you don't lower the car, you might be OK, however.
I have 225/55/16 tires on 7.5" wide wheels with a 40 offset. I also have the Tokico/Eibach set-up. Under heavy loads, or when cornering hard, I got some rubbing. I had the fenders rolled a little to take care of it. You proposed combinition has a larger diameter tire, wider wheels, and an offset that will bring your wheels outside even farther. Need I say more? I think I'd look for something else.
cdssolara
Postby xyntax » Fri May 02, 2003 10:43 am
cdssolara wrote:I have 225/55/16 tires on 7.5" wide wheels with a 40 offset. I also have the Tokico/Eibach set-up. Under heavy loads, or when cornering hard, I got some rubbing. I had the fenders rolled a little to take care of it...
Question: So if you didn't lower your car (kept stock suspension) and have a wheel setup like that, you wouldn't have a rubbing problem then? I know lowering it looks better though.
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby cdssolara » Fri May 02, 2003 11:26 am
If you mean with a wheel set-up like mine, then no, there wouldn't be any rubbing if the car was not lowered. With the one that Screwdriver is proposing, I'm not so sure. My guess is that it probably would not rub, although it's possible under extreme driving conditions or with a lot of weight in the car. The tires he's talking about are an inch larger in diameter than stock.
cdssolara
Postby Screwdriver » Fri May 02, 2003 12:58 pm
Actually, Even at Stock Suspension, the tires rub VERY marginally at the rear. 1-2 mm would have made the difference.
Im either going to buy just the rims from the guy, or look for a different set.
Thanks
Aviv :evilbat:
Screwdriver
Postby Flipside909 » Fri May 02, 2003 2:43 pm
You're better off looking for a different set.
www.clublexus.com
Flipside909
