SolaraGuy.com • View topic - Staggered Rims?
Staggered Rims?
Staggered Rims?
Postby netherland24 » Fri Sep 28, 2007 9:22 am
What is the max width that will be alowed on the rear of the car? 9? and front is 8?
00 SS Lara 277hp
05 DODGE RAM 1500 n/a
netherland24
Postby netherland24 » Fri Sep 28, 2007 9:24 am
17" x 9" +35 offset REAR______??? si o NO?
00 SS Lara 277hp
netherland24
Postby Biggi_e » Fri Sep 28, 2007 10:10 am
get 18's. i think 17's look too small on our cars
Postby Sebas007 » Fri Sep 28, 2007 10:15 am
Regarding the look...
18's on gen 1 = 19's on gen 2
because of the shape and height of the body.
I think if you don't have widebody kit you wouldn't be able to make it fit 9" wheels especially with lower offset. Lower offset move your wheels toward outside the car. You were talking of widebody kit...don't you still go with it ??
Postby woa_its_j3ff » Fri Sep 28, 2007 10:40 am
Sebas007 wrote:Regarding the look...
+1
19s dont look bad either but potholes! :o .. Reggie (NVdis1) has 19s and they look amazing. I used to have 17s, and yes they are way too small. I Like the 18s I have now. it's a perfect balance between 19s and 17s in terms of size and ride quality. (depending on your suspension work and tires of course. ;))
Postby Toy1mzfe » Fri Sep 28, 2007 11:16 am
im rolling on 19's on 235 35 19 tires and potholes isnt too big of a deal. i hit like the fattest pothole ever and like my broadway fell down. hella nuts. and no dents. nothing. so its a matter of what material.
so far from what i read on SG is 8.5 iono about 9.. might be pushing it.
Postby blaK » Fri Sep 28, 2007 1:20 pm
Staggered are for rear wheel drive.
blaK
Postby s15lara » Fri Sep 28, 2007 7:16 pm
front 9 inches and rear 11 inches ;)
almost there...what do you think?
s15lara
Postby Jon11582 » Fri Sep 28, 2007 7:26 pm
I think in stock form, rear is more constricting than the front.
I know you have to be very particular about the offset for the rear fitment with 8+ inches to prevent rubbing, but I haven't heard the front be an issue with rubbing.
2000 Black Solara SE
Jon11582
Postby ThatVietGuy » Fri Sep 28, 2007 7:42 pm
Jon11582 wrote:I think in stock form, rear is more constricting than the front.
Not to mention there is hardly any lip on the front fenders as compared to the rear fenders
ThatVietGuy
Postby AguinaldoHomes Inc » Fri Sep 28, 2007 8:05 pm
I just got a set of 19 x 8.5 35 Offset for the my 03 Solara. The fenders definitely had to be rolled. Actually I was gonna go for 20s but i hate the look of all-rim-and-no-tire look.
Mark Aguinaldo
Aguinaldo Homes, Inc.
(908) 220-3692
aguinaldohomes@yahoo.com
AguinaldoHomes Inc
Postby netherland24 » Fri Sep 28, 2007 8:17 pm
well i wanted to go 8s on the front and 9s on the rear
00 SS Lara 277hp
netherland24
Postby indiglosolara » Sat Sep 29, 2007 12:17 am
9" will fit in the rear with +30 offset or so, fenders rolled, tire stretch and maybe some negative camber...
8.5 with a +35 offset fits good.. but you will still need to roll your fenders.. anything with a 8" wide with anywhere from a +38 to +35 offset will need fenders rolled depending on the type of tire you run...
This is for the rear set-up BTW.. the front with a 8.5" with a +37 offset will fit flush with your fenders
or 8" with a +35 to +38 offset is close to flush...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby AguinaldoHomes Inc » Mon Oct 01, 2007 1:44 pm
9.5" width in the rear definitely will look funny on gen 1 to gen 1.5 solaras because like everyone here says, there's just not enough flare to the rear to cover the width of that size wheel. Forget about stretching tires and all that compromises man...8.0 to 8.5 width should be a perfect match...My wheels are the same ones from a member in this forum except hers were 18's and mine were 19's and chrome (gots to bling n mean!!!).
I just purchased the JiC FLT-A2 Coilovers and I will be installing the whole set together this coming springtime...no need to show now since cold season's about to start.
Mark Aguinaldo
(908) 220-3692
AguinaldoHomes Inc
