SolaraGuy.com • View topic - Would this mod hurt my car?
Postby atclate » Thu Oct 04, 2007 1:27 am
So, I have read the thread about tightening the wires connecting to the throttle body would make my solara faster. One is the throttle position, and the other one is for the transmission(mine is auto).
I have tried both, and here is what I think:
I think the TB one feels like all it does is stepping on the gas harder, cos It gives me around 1200rpm idle speed with a hot engine, when it should be less than 1000. So, I'm just tightening it so much that it responses right away when I step on the gas. (I don't want to waste the gas when I'm at the stop light)
I think the other wire is really making a difference. After tightening it, the transmission is responding quicker, and it pushes harder. I'm looking at the rpm, and the same rpm gives me more push. This is why I'm tighening this wire as tight as possible(I made it so tight that the bolt is almost pushing off the rubber thing, if you understand what I mean)
But I wonder if this is actually hurting my transmission/drivetrain by putting more pressure on it or something, or maybe wearing some kind of "clutch equivalent on the manual". (I don't really understand how automatic transmissions work)
I'm just trying to find the sweet spot between performance and reliability.
atclate
Postby nemoxfishy » Thu Oct 04, 2007 4:04 am
i thought the "other wire" is the wire connected to the cruise control ? if u trace back to, following the wire, i think it does link to the cruise control.
it might just be your FEELING ... correct me if im wrong.~
nemoxfishy
Postby redgen1 » Thu Oct 04, 2007 4:28 am
nah im pretty sure youre right /\ -- i did this mod a few months back for the tranny line, changing the pressure in the TB by tightening it to get shorter auto shifts it does work. buuuut if you go too tight then at WOT you lose a bit of power, seems to be about right.. i fooled around with it for a while
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby Midias » Thu Oct 04, 2007 5:51 am
If you really feel the need to tighten the throttle cable. Start by tightning it with the car running untill the RPMs rise a little then back off a 1/4 turn and you should be set.
Postby SleeperSolara » Thu Oct 04, 2007 7:27 am
Yeah i did this mods a couple weeks ago.
I did notice that i did lose a little speed at the top end, but shiftin' faster is nicer, IMO.
I didn't turn mine that much either.
Postby atclate » Thu Oct 04, 2007 9:44 am
Oh~~~ I didn't realize the tranny wire would make me lose WOT power.
seems like I'd need to tune it so that I get the most power at my daily driving level.
And I'm guessing it doesn't hurt my car...
atclate
Postby fastsolara » Thu Oct 04, 2007 7:43 pm
so, this does something for the autos, not the manuals
2000 Solara SE V6 5sp w/ all options, 57k
6000k HID head lights
8000k HID fog lights
Reverse Indiglo Gauges
Performance Chip
Custom black grill (very nice)
20% tinted windows
Supra Brake Calipers
fastsolara
Postby Eye8Pussies » Thu Oct 04, 2007 8:02 pm
it's just adjusting the kickdown cable...
so...no, it won't work on a 5-speed, since we can shift as fast as we want anyway ;)
Postby xet » Thu Oct 04, 2007 10:17 pm
i did it early in the summer and my car is fine
1998 camry xle
2005 g35 coupe 6mt
xet
