SolaraGuy.com • View topic - The Big 3
The Big 3
The Big 3
Postby AllShowNoGo » Tue Oct 23, 2007 7:15 am
Been looking at upgrading the major ground points in my car. I can do the aternator to battery+, and the battery to negative chasis, but where is the original engine ground to chassis on a 2000 v6 solara. OR can someone tell me a good place to run the new wire. Was thinking about running the wire from the aternator bracket to chassis ground.
AllShowNoGo
Postby Sebas007 » Tue Oct 23, 2007 7:29 am
Tranny to battery holder...battery holder to chassis (stock ground point on Gen 2 and probably gen 1)
Postby Chinky420 » Tue Oct 23, 2007 9:57 am
the ground points i'm running right now is as follows:
stock chassis ground (below air intake, driver side of the block) -----> battery neg
battery neg ------> new chassis ground/screwhole for old airbox
new chassis ground --------> throttle body
new chassis ground --------> engine block (driver side, found a nut that is at the edge of the block).
i only used those points at the time being since i had only a few pairs of terminal connectors. yesterday i did receive more wiring and connectors from knukonceptz though, so this weekend i'm going to go ahead and make a connection for the pass. side chassis ground (looks like it goes from the pass. side of the block to the pass. side chassis), as well as a couple other points.
PEOPLE WITH GROUND WIRES, what ground points did ya'll hook up to? also, would it be a good idea to upgrade the stock cables (battery+/-) with the 4AWG wire i have, or is the amp power wire i have not properly shielded for the load and the heat stress of being a main power wire?
Chinky420
Postby AllShowNoGo » Tue Oct 23, 2007 11:09 am
thanks for the help
One more question. I have 2 gauge running too my amps and a 2 gauge ground in the trunk should I use 2 gauge for my new grounds under the hood?
AllShowNoGo
Postby SolaraGuy22 » Tue Oct 23, 2007 4:06 pm
Yeah that shouldn't be a problem. Don't replace the original ground wires just run the new ones along side of it. It takes the path of least resistance.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
