SolaraGuy.com • View topic - supercharger question
Postby venom » Thu May 22, 2003 7:29 pm
I have a supercharger in my solara since Dec, Every thing was
great untill today when I got out of work I hit the pedal to pass a
a car and all of a sudden my car felt like it was losing power. As
soon as I hit 2nd gear it stopped jerking and the boost hit. I went
driving around stepping on the pedal to see if it will happen again,
but I it ran smooth. So later that day after it was parked for a few
hours I tried it again and it did the same thing as before. I don't
know what it can be. Is something wrong or is that normal??
venom
Postby chef solara » Fri May 23, 2003 6:10 am
Well, who installed the S/C? I would have toyota take a look, to make sure that everthing is O.K.
Explain more on the losing of power, there is no boost in first gear with the autos. With the EBC, it cuts boost in between shifts. Is that what your talking about?
chef solara
Postby venom » Fri May 23, 2003 7:57 pm
A friend and I installed it, but the thing is it never did the jerking motion
before. It's just when I first drive off when my car starts to jerk it feels like I'm not accelorating, just staying in the same speed. But if I keep driving it's like it never happed.
venom
Postby Yanks0114 » Fri May 23, 2003 8:52 pm
you are going to have to explain your situation a little better...
Postby impactX » Fri May 23, 2003 9:46 pm
Auto? Manual?
You are not "supposed" to have boost in first gear auto if you have the ebc.
impactX
Postby Flipside909 » Tue May 27, 2003 11:35 am
venom wrote:A friend and I installed it, but the thing is it never did the jerking motion
Belt slippage.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby venom » Tue May 27, 2003 9:46 pm
Is there something I can do to stop the belt from slipping?
venom
Postby DavPak » Wed May 28, 2003 4:56 am
make sure the belt tensioner is working properly
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Yanks0114 » Wed May 28, 2003 10:44 am
venom wrote:Is there something I can do to stop the belt from slipping?
If you have a smaller pulley either put back on stock or readjust the belt tensioner. Also there are belts available with lots of little teeth to help grip the pulley better. I believe bigflyjet has one.
Postby venom » Wed May 28, 2003 7:20 pm
Thanks guys for your advise, I will adjust the the belt tensioner hope
that will work.
venom
Postby krook » Wed May 28, 2003 7:49 pm
venom wrote:Thanks guys for your advise, I will adjust the the belt tensioner hope
that will work.
i thought the s/c kits that came with the belt tensioner are spring loaded, thereby, eliminating the need for manual adjustment?
krook
