SolaraGuy.com • View topic - Best tire size for the stock rims.
Postby HydroponiK » Sun May 25, 2003 6:18 pm
My stock Michelin MXV4+ (205/60-16) are wearing thin and I'm looking to buy new tires for the stock 16" rims. What would be the best tire size to get for better performance and looks?
HydroponiK
Postby impactX » Sun May 25, 2003 7:16 pm
205-60-16
impactX
Postby cdssolara » Sun May 25, 2003 11:10 pm
The only other size that you can even think about is 225/55/16, although they are at the limit for that narrow of a rim. It will fit, but the tires look a little pinched and the sidewall seems to bulge slightly. I know of several people who have used that size, though, and they have all been happy with it.
cdssolara
Postby Mole » Mon May 26, 2003 1:29 am
i never thought of 225, but 215/55 were pretty good on my stock rollers.
225 will fit, but it will look too much of a trapezoid
Postby HydroponiK » Mon May 26, 2003 12:17 pm
Thanks for the advice guys.
On another note, I remember there was a site showing how off your speedometer would be with different tire sizes/ratio. Do any of you remember it?
HydroponiK
Postby mlimin » Mon May 26, 2003 5:21 pm
get bridgestone S-03
mlimin
Postby Mole » Mon May 26, 2003 7:05 pm
HydroponiK wrote:Thanks for the advice guys.
yeah, it is true in extreme cases like 65 to 40 series, but going from 65 to 55 is fine. (all with the 16' wheel)
Postby Yanks0114 » Mon May 26, 2003 8:12 pm
Mike is right.
For the most part the speedometer will be fine, unless you change rim sizes, from 16 to 18 or go through extreme changes in tire size.
Postby cdssolara » Tue May 27, 2003 12:12 am
Yes, here's the website; I use it all the time for reference:
http://www.miata.net/garage/tirecalc.html
215/55/16 will be a little smaller diameter than stock, but it won't cause problems with your ABS and the speedo error is minimal. The 225/55/16 size is almost the exact diameter as stock. As someone else mentioned, the 215 will probably look better on your stock rims.
cdssolara
Postby HydroponiK » Tue May 27, 2003 6:51 am
Wow, great responses! Thank you all for your help. :D
HydroponiK
speedo check
Postby burgerman » Thu Jun 05, 2003 8:23 pm
Check out www.1010tires.com. They have a calulator that lets you compare two sizes side by side. 8)
burgerman
Postby ICrazyChrisI » Fri Jun 06, 2003 2:06 am
I got a quick question..with bigger rims, does that make your fuel economy worse?
ICrazyChrisI
Postby impactX » Fri Jun 06, 2003 3:59 am
ICrazyChrisI wrote:I got a quick question..with bigger rims, does that make your fuel economy worse?
If the overall weight of tires + rims are the same, then it shouldn't affect the milage at all.
impactX
Postby cdssolara » Fri Jun 06, 2003 8:19 am
Like impactX said, there will be no impact if the overall weight remains the same. If you significantly increase your rim diameter and width (like going from 16 x 6 to 19 X 8), the rims tend to get heavier. This can impact the mileage, but it shouldn't be a huge factor. It will also slow down your launch, if you're into going to the strip. You can buy lightweight wheels, but they tend to be very expensive.
cdssolara
Postby Whatever » Fri Jun 06, 2003 11:58 am
Toyo tires for toyota cars :D :lol:
Whatever
