SolaraGuy.com • View topic - wierd oil changeing method?
Postby rewmomi » Tue Mar 11, 2008 7:45 pm
My mechanic told me thatif I really wanted to clean out the interior of my engine I should change the oil and put 3 quarts of oil and 2 quarts of tranny oil. He said that tranny oil is nothing but a cleaning solution. Should I go through with it?
rewmomi
Postby bassthrive » Tue Mar 11, 2008 8:07 pm
I'll stick with a 1/3 can of seafoam in the crankcase before my oil change. (other 2/3 goes in the gas and in the brake booster line)
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby NeFaRiOuS_SLE » Tue Mar 11, 2008 8:48 pm
I used to do that back in the day, except I used 1/2 quart of tranny oil 100 or so miles before the oil change.
Postby rewmomi » Wed Mar 12, 2008 8:02 am
NeFaRiOuS_SLE wrote:I used to do that back in the day, except I used 1/2 quart of tranny oil 100 or so miles before the oil change.
yeah he told me to change my oil again as in 3 oil an 2 tranny and drive the ride for about 1000 miles and then change your oil again lol idk ill try it a see how it goes i guess?
rewmomi
Postby Midias » Wed Mar 12, 2008 8:15 am
I usually dump a quart through the engine every 3rd time with the drain plug off it pushes some extra black crap out before it runs clear. Any use sea foam about 500 miles before each oil change.
Postby NeFaRiOuS_SLE » Thu Mar 13, 2008 10:36 pm
^Well again, I only used the tranny fluid method on my Buick, but I didn't change my own oil back then; even so, I noticed the car ran a bit smoother and a butt dyno returned a stronger power curve 8) . Nowadays I use Sea Foam every few changes, and the oil IS definitely darker!
