SolaraGuy.com • View topic - Clear Corner Seal up
Postby adam2562 » Wed Jun 04, 2003 8:06 am
when u guys seal up your clear corners... do u just take the sealer and go around the edge again.. or do you heat it up and take it apart and do it over :roll:
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby TadS » Wed Jun 04, 2003 9:04 am
I just went around the edge of the housing, where the seam is visible. No condensation since.
TadS
Postby FLASH » Wed Jun 04, 2003 5:51 pm
I took off that black rubber thats already there and sealed the seam and superglued the rubber back on....STILL got a little condensation though.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby adam2562 » Wed Jun 04, 2003 9:31 pm
thanks for the replies guys... and one more question.. wut stuff did u use to seal it up?
adam2562
Postby Missay » Wed Jun 04, 2003 9:38 pm
Adam2562 wrote:wut stuff did u use to seal it up?
aquarium silicon gel...i figure, it's strong enough to keep water/fish from escaping from a fish tank, it's strong enough to keep water out of cheap plastic :P
Melissa
Missay
SolaraGuy Ambassador
Postby FLASH » Thu Jun 05, 2003 4:52 am
Super Glue works pretty good, too. But Silicone is reccommended. [sp?]
==FLASH==
FLASH
