SolaraGuy.com • View topic - 2003 Solara/Offset Question/Will these wheels fit?
Postby Ry » Thu Jun 19, 2003 11:45 pm
The wheels are a 17" 5-spoke design by Forte.
Rim size is 17 X 7
5-lug Universal bolt pattern
Fits 5 X 100 and 5 X 114.3
Offset is 48.
Hub Diameter is 74.
Will this fit a 2003 Solara?
Thanks.
Ry
Postby Ry » Thu Jun 19, 2003 11:46 pm
Here's another shot:
Ry
Postby Mole » Fri Jun 20, 2003 2:17 am
you are comming offly close to rubbing the strut shaft. it would be better if it were 45-38 offset....
depending on what tire is used, you might be ok.
Postby Ry » Fri Jun 20, 2003 4:17 pm
TRDMole177 wrote:you are comming offly close to rubbing the strut shaft. it would be better if it were 45-38 offset....
Thanks TRDMole. The tires are either going to be 225/55, 215/55, 225/50, or 215/50. Not sure yet though.
Would like to get more responses..
Ry
Postby indiglosolara » Fri Jun 20, 2003 5:08 pm
If the offset is 48 with the 225 or the 215 your going to Rub.... with a 45 or 46 offset your coming really close. i would recommend that you get a 2mm or 3mm spacer before you install the rims.
I have a set of 45offset and i am really close with the 225 tires.
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby impactX » Fri Jun 20, 2003 6:01 pm
It will rubb...
I have 17x7 +40 and it doesn't have much space for strut clearance.
impactX
Postby Ry » Fri Jun 20, 2003 8:42 pm
Cool. Thanks guys. Can anyone recommend good spacers? How much do spacers usually run?
Ry
Postby xXsolaraXx » Fri Jun 20, 2003 9:46 pm
try the SEARCH function for all of your spacer needs...ur welcome! hehehe jp L8r moe :evilbat:
xXsolaraXx
Postby Ry » Fri Jun 20, 2003 9:53 pm
xXsolaraXx wrote:try the SEARCH function for all of your spacer needs...ur welcome! hehehe jp L8r moe :evilbat:
There were recommended on another Toyota forum: http://www.hrsprings.com/site/products/trak.html
Ry
Postby xXsolaraXx » Fri Jun 20, 2003 10:11 pm
ok...good luck! just remember there is a warning for using spacers...something about the lug nuts not being 100% secured...ask yanks or flip for more info...moe
xXsolaraXx
Postby Yanks0114 » Sat Jun 21, 2003 8:31 am
Spacers eat up some of the available threads for the lug nut. Instead of possibly getting 10 full turns, you may only get 6-7. This means more stress on both the lugs and the nuts. Some people have stripped their lugs or lug nuts.
We've had an exntensive discussion about spacers so please use the search function
Postby impactX » Sun Jun 22, 2003 2:11 am
Try not to use spacer if possible....
Hub centric is the way.
impactX
Offset Question
Postby Darren » Mon Jul 07, 2003 4:28 pm
How does offset work. If I understand correctly it measures how a wheel will fit in relation to the frame, but I am not sure how it works. Is it the lesser or greater the offset that determines the widest stance? And what is the widest offset that you would recomend? If it helps I am looking for 18x7.5 wheels no decisions on tires yet I want to find the right wheels first.
Darren
