SolaraGuy.com • View topic - NEED HELP: S/C is broken?
Postby Russian Guy » Thu Jun 26, 2003 10:17 pm
Let me tell you the problem:
I installed my S/C 2 weeks ago and had a lot of fun driving on the streets…=)
Some days ago in morning on my way to the job when I took my car from the garage "Check engine" and "Traction Control" lights appeared on my gauges… I was very surprised but decided to drive the car. Then I mentioned that S/C makes a noise not as usual but a hissing noise. I pushed my car but felt no gain !!! It was like I have no S/C but I still heard the noise from S/C. EBC and all mechanical connections are installed correctly so I'm completely confused and don’t know what to do…
Any solutions or advices?
1MZ-FE TRD S/C. 2 BLITZ NUR Spec mufflers. SPA Boost/Fuel + Revotec water/oil/volt gauges. BLITZ Powermeter ID III, Denso IK 22 Iridium, TRD brake lines, TRD rear sway bar, fuel pump upgrade
Russian Guy
Postby Ragtop George » Fri Jun 27, 2003 9:19 am
Sounds like you have a vacuum hose that is unplugged. The boost bypass control in the supercharger is vacuum controlled, if a vacuum line is unplugged you may be losing boost.
George
2002 Solara Convertible Automatic
TRD Supercharger, 6 PSI pulley
Apexi WS exhaust, custom Y pipe
TRD RSB on "track" setting
Ragtop George
Postby Russian Guy » Sun Jun 29, 2003 10:37 pm
Thanks. I will check. :wink:
Any other comments?
Russian Guy
