SolaraGuy.com • View topic - ABS Light Trouble
ABS Light Trouble
ABS Light Trouble
Postby tomlee » Sat Jun 28, 2003 1:20 am
I installed my springs today and for some reason my ABS Light is on. Does anyone know how to turn it off? Is there something I need to do?
tomlee
Postby jephry2000 » Sun Jun 29, 2003 5:13 pm
Brother, the same thing happened to me... What happened was that when they installed my springs they left the wires hanging and screwed up the sensor. I took it to the dealership and it was 170 to fix. Warranty covered the parts. The problem is you have to find which sensor is broken.... Good luck....
jephry2000
Postby tomlee » Sun Jun 29, 2003 9:08 pm
damn 170? where are the wires located?
tomlee
Postby impactX » Mon Jun 30, 2003 2:49 am
The clip is on the strut and the wire connects to the caliper
impactX
Postby tomlee » Mon Jun 30, 2003 9:09 pm
so if i put the wire back will the light go off?
tomlee
Postby krazeee1707 » Mon Jun 30, 2003 10:24 pm
sorry bro. Same thing happened to me. Someone told me they went to some junk yard and bought the abs sensor. I'm assuming that what my problem is. It's been about a year now, and the light is still on. Hopefully, I'll get around to it soon. haha.
krazeee1707
Postby Luc » Mon Jun 30, 2003 10:29 pm
This problem isn't as simple as just "reinserting" the wire back. If the contact is torn from the sensor, the wire and/or sensor needs to be replaced. This problem always arises from carelessness of not support the axle carriers when the strut/spring assemblies are taken out. Unless the suspension was self-changed, go back to the shop and tell them to pay for the damages, written down on paper.
1998 S/C'd 1MZ-FE A/T
Luc
Postby tomlee » Tue Jul 01, 2003 6:53 am
Unforunetly i was the one who put the springs in. would I be able to go to Toyota and get warranty on it? If not how much would it cost?
tomlee
Postby DavPak » Tue Jul 01, 2003 7:33 am
tomlee wrote:Unforunetly i was the one who put the springs in. would I be able to go to Toyota and get warranty on it? If not how much would it cost?
not likely. as soon as they see the aftermarket springs in, they'll deny you.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Luc » Tue Jul 01, 2003 8:01 am
You can try and take it to your dealer if the car is still under the warranty. Mention that there was a TSB about the fragility of the sensors also. Mine was actually covered under warranty even after they saw the lowering springs, so it would depend on your dealer.
Luc
