batteries...?
Does anyone know how to extend the terminals on the battery, so you can put in a yellow top optima battery?
- 626
808Camry wrote:cut off the terminals, use a 4 gauge butt connector and 4 gauge wiring to extend the power wire and then on the other end put your new terminal on. For the ground you can do the same, or you could just use 4 gauge ring terminals and 4 gauge ground wire and replace the entire ground itself. Hope that helps!
