SolaraGuy.com • View topic - Shocks or Springs Noise
Postby cruze105 » Tue Jul 08, 2003 3:17 pm
i recently had my shocks and lower springs installed about 30 days ago, yesterday as i was riding heard rattling noise coming from the rear right wheel as i went over little bumps.It seem to me that its either the shock or the spring. My friend saids this is normal since they are new and they need to set in. But the noise is really troubling me im not sure what it can be. Anyone have this problem.
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
Postby WTF?? » Tue Jul 08, 2003 3:34 pm
give it another couple days of driving... if it doesnt stop id bring it back to whoever you had it installed... something might be loose.
i let mine settle in about 500-700mi then had the alignment... everything seems ok... hows the handling for you?
Retired... its been fun Image
WTF??
Postby Jackass-Jeff » Tue Jul 08, 2003 3:54 pm
I had that problem... I took it into the dealer and they said it was the "bushings" or something on the rear sway bar that needed to be oiled. Call and ask a dealer tech I guess
1GR-FE ftw!
Jackass-Jeff
Postby Hsakuragi » Tue Jul 08, 2003 10:37 pm
do you think wd40 will do the noise? seems the noise comes only when i drive slow or on bumpy road. So if wd can, do i really need to take off the bushing or i can just use the straw and spray inside the bushig...it's bugging me, i don't want to go back to dealer cuz they take forever...
Hsakuragi
Postby Yanks0114 » Tue Jul 08, 2003 11:04 pm
use lithium grease
Postby Hsakuragi » Tue Jul 08, 2003 11:07 pm
so i do have to take the bushing off again huh...
Hsakuragi
Postby cruze105 » Wed Jul 09, 2003 2:04 pm
im gonna take it back to shop where i got it installed, like what yanks said probably needs grease. The noise is really irritating me and only happens when i go over bumps and stuff, i hope its just need to be greased up or suttinn
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
Postby Jai_Jai_Binks » Wed Jul 09, 2003 2:12 pm
Not to much sure about your car (what model year or type) assumed it to be 2002 sev6
there are 2 TSB's for that car
SU001-03; JAN 03; Suspension - Front Suspension Thump/Knock Noise
SU002-03; JAN 03; Suspension - Rear Suspension Knock/Thump Noise
If the lubing doesn't solve that...and the guy who installed doesn't help...you might see if these you qualify for??
Postby kondo » Wed Jul 09, 2003 2:30 pm
I had a issue with a lot of noise comming from the back of my car a month after getting it lowered and it turned out to be that the rear sway bar got screwed up from having my car put on a lift.
kondo
SolaraGuy StickerGuy
Postby WTF?? » Wed Jul 09, 2003 3:27 pm
cruze105.... you dont have a sway bar do you?
WTF??
Postby cruze105 » Wed Jul 09, 2003 4:53 pm
i dont have any aftermarket sway bar. But planning on getting the trd sway bar soon.
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
Postby cruze105 » Wed Jul 09, 2003 4:55 pm
i have solara 2002 4cyl
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
Postby buss-it » Wed Jul 09, 2003 5:40 pm
i need new suspention but dont know what 2 get. i need a really smooth ride but i still want the drop. what can i get???????
buss-it
Postby Yanks0114 » Wed Jul 09, 2003 5:50 pm
buss-it wrote:i need new suspention but dont know what 2 get. i need a really smooth ride but i still want the drop. what can i get???????
Best bet is the eibach springs/tokico struts and TRD RSB (optional). You'll preserve that nice ride while significantly improving handling. Do a search and I'm sure you'll find a ton of responses on this
Postby Hsakuragi » Wed Jul 09, 2003 9:03 pm
Yanks0114 wrote:use lithium grease
ok, brought it for kragen, it's 4.99 in 2 big a$$ tubes, why the heck i need all those for? but they only have that one, i'm going to re-grease it after work tomorrow, wish me luck. By the way, do i have to remove the grease that's already on the bushing before re-grease? If yes, wat;s good to remove?
Hsakuragi
