SolaraGuy.com • View topic - SUPERCHARGER INSTALL
Postby GNAW » Mon Jul 21, 2003 11:11 am
Hey guys, this pose is for 2 reasons....
One, im in NORCAL, SAN JOSE area and im getting my charger in so im hoping to find a good place for my gauges install (airfuel, and boost) unless its a really easy job and i can do it myself. I already have them but im kinda nervous about the install.
Two, my solara went into Toyota on friday for the install and they quoted me 685 for the supercharger install plus changing the spark plugs which wasnt too bad i think, they said they usually charge 220 for the spark plugs even if you already have them, sounded kinda like crap but i wasnt sure. Also they called me this morning saying that they were gonna charge me another 165 since i have a PSII under the glove and it blocking a step of the install, NOW I JUST WANT TO KNOW IF THATS COMPLETE BS, or is it pretty crucial, i mean even if it is i can take that thing out in like 25 min but their expecting to charge me 165.. but since i dunno how the charger install goes im not sure if their just messing with me... I HAVE TO ASK...
THANKX IN ADVACE... david
GNAW
Postby DavPak » Mon Jul 21, 2003 11:37 am
go spend the 25 mins and remove the PSII
save the $165....you'll need it to buy premium gas out it Cali!
$685 sounds steep. at $80/hr, that's over 8.5 hrs labor. should be around 6 hrs labor (standard time). that puts it ~$480. tell them you got a quote from another dealer that they'd do it for $480 but you don't like that dealer and wanted to go to them instead. they'll think they will earn a customer if they knock the price down. trust me, i do this all day long!
'02 Solara S/C'ed V6 5-spd
DavPak
Postby geminimouse » Mon Jul 21, 2003 11:50 am
I changed all six spark plugs for my solara in less than an hour in my home garage. Dunno why they would charge 220 for it. Charging $165 just cause something is in the glovebox is BS. They probably don't know how to take it out, so they'll charge as much as they can for labor.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby krook » Mon Jul 21, 2003 1:24 pm
geminimouse wrote: Charging $165 just cause something is in the glovebox is BS. They probably don't know how to take it out, so they'll charge as much as they can for labor.
actually, no. you need to access the area behind the glove box in order to install the EBC, so no that's not BS. just remove your PSII and save yourself the money.
krook
Postby xXsolaraXx » Mon Jul 21, 2003 3:07 pm
krooked is right...the area behind the glove box is important for the supercharger computer(electronic boost controller) if they are charging you 165 to remove it and then install it again, it sounds accurate...however i wouldnt let them, instead i would go and remove it myself...but the info they gave you is not BS. L8r moe
xXsolaraXx
Postby Guest » Mon Jul 21, 2003 4:55 pm
Thank guys, i just got the car back and they charged me 598 total, with the spark plugs, so i guess it wasn't as bad. I went for a test drive and boy do i love that sound, but i dunno i just dont feel the pull that much, maybe since i have an AUTO.
Now im looking for a good play for the gauges install and probably also an upgraded pulley....
thankx
Guest
Postby Guest » Mon Jul 21, 2003 4:58 pm
CORRECTION :
good place, not play....
Guest
Postby geminimouse » Mon Jul 21, 2003 8:39 pm
krooked Solara wrote:actually, no. you need to access the area behind the glove box in order to install the EBC, so no that's not BS. just remove your PSII and save yourself the money.
I wasn't saying that they didn't have to go behind the glovebox, I was just saying the price is too high.
GNAW, have fun with the new supercharger.
08 Accord Coupe
geminimouse
Postby Fletch » Tue Jul 22, 2003 3:35 am
It took my local mechanic 8 hrs over the span of a few days to do the install. He has a lot of experience, but had never installed a supercharger on a 1mz-fe. At $50/hr I thought it was still a resonable price.
2006 Legacy GT spec.B
Fletch
Postby Jai_Jai_Binks » Tue Jul 22, 2003 7:18 am
Should have read this sooner..would have recommended steve from sc3!
Postby GNAW » Tue Jul 22, 2003 3:24 pm
Does he do gauges?? or can he do the pulley change im still in need of those installs..
Also, i was running my car much harder today and i cant help but hate the gear changes in my auto when i mash the pedal. Im assuming its just an auto problem cause i dont have this problem on my eclipse but when i floor it and it gears up the RPM drops really low and it feels like im lightly breaking, i never really noticed it till after i installed the charger, do others who have an auto have the same situation or is it just me ?
And thankx geminimouse... im already having a blast
GNAW
Postby xXsolaraXx » Tue Jul 22, 2003 3:32 pm
what you are feeling is a loss in boost between gear shifts...its normal...all auto's will drop boost while switching gears...also you might want to know the first time i got my s/c installed i felt a very light boost also...i finally got my boost measure and saw i was only getting 1.5 psi...i took my car back to the dealership and they kept it for a few more days the problem was in the ebc; it wasnt wired correctly or something, so they replaced it and also there was a loose vaccum hose; when i got my car back i was reading about 3.8 to 4.0 psi and it felt muuuuch better...so get the boost gauge ASAP it might tell you something you dont know! L8r moe (hope this helped)
ps: alot of people say if wired correctly an auto should not recieve boost in 1st gear, mine and yanks0114's s/c do recieve it in first while wired correctly...are you getting any in 1st?
xXsolaraXx
Postby GNAW » Tue Jul 22, 2003 3:47 pm
Dayam... i wish i knew... im can definately hear the charger spin.. but i think i might have the same problem as you...
i have the boost gauge (and airfuel gauge) just sitting there looking at me... i wish i knew how to install it so i can find out if TRD messed up my crap.. haha but once i get it in ill be sure to let u guys know if im getting boost in first..
I have read all the posts and agruments on the subject.. very interesting....
TACH another supercharged auto to the forum.. hahaha..= )
GNAW
Postby GNAW » Tue Jul 22, 2003 3:56 pm
also L8R MOE, just wondering how little your boost felt ?? cause mine does feel really low.. i can definately hear the WHINE.. but im sure that doesnt mean im getting boost, i bought my charger from this forum a LONGG time ago and never got a chance to install it till recently so im hoping its not something i need to replace...
is there another way i can test it.. like 0-60 time.. maybe i can compare it with yours.
any advice would help, thankx
GNAW
Postby sOLaRa 4o8 » Tue Jul 22, 2003 11:07 pm
What dealership did you goto? I'm from San Jose too..
sOLaRa 4o8
