SolaraGuy.com • View topic - Drifting..
Drifting..
Drifting..
Postby Grazi07 » Tue Oct 14, 2003 9:02 am
I haven't seen much posted about drifting and from the vids and pics it looks like a lot of fun. What does it take to make a good drifting car? Is it all in the tires and suspension? Are solara's drift-able?
Team Nex-Gen: The new breed of speed!
Check us out at www.teamnexgen.net
Grazi07
SolaraGuy UConn Guy
SolaraGuy UConn Guy
Postby TadS » Tue Oct 14, 2003 9:26 am
I think you need power to the rear wheels to drift. I don't think that you can do it in a FWD car.
And yes it does look fun :).
TadS
Postby Jackass-Jeff » Tue Oct 14, 2003 9:31 am
Drift : Sliding the rear wheels around to do sharper turns while at high revs so you don't lose too much speed.
That's the theory behind it, but I'm sure it's all crap =P
FR car around 2900 lbs with 400 hp is really good from whta I hear...
1GR-FE ftw!
Jackass-Jeff
Postby WTF?? » Tue Oct 14, 2003 9:49 am
Drifting with rwd is easier...
my homeboiz nissan 240 is hella fun to drift in!!! but damm poor tires!!! :oops:
but like raveboi says, you gotta be able to gain control RIGHT AWAY after you drift or youll lose control
Retired... its been fun Image
WTF??
Postby DavPak » Tue Oct 14, 2003 11:21 am
what does it take: RWD car, lots of practice.
go play GT3 in 'drift' mode, you'll see how hard it is :lol: :lol:
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Mole » Tue Oct 14, 2003 12:15 pm
FF can be drifted. the only method of drifting FF is using the Ebrake to break traction on the rear tires.
that is why FR cars have an easier time doing so.
dont bother trying to do this at first glance. it takes A LOT of practice to achieve novice level of drifting.
Postby HKSV6SLE » Tue Oct 14, 2003 12:47 pm
solaras acan be drifted but iuts harder and not the ideal setup but again not impossible...
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby B_Master_Flash » Tue Oct 14, 2003 1:18 pm
I think AWD cars drift the best, E-Brake drifting, although fun at low speeds, is extremely dangerous at high speeds (if you hit the e-brake just a little too hard youre toast)
B_Master_Flash
Postby Jackass-Jeff » Tue Oct 14, 2003 1:42 pm
Best words might be:
Leave it to the pros =P D1GP
1GR-FE ftw!
Jackass-Jeff
Postby Mole » Tue Oct 14, 2003 2:29 pm
B_Master_Flash wrote:I think AWD cars drift the best, E-Brake drifting, although fun at low speeds, is extremely dangerous at high speeds (if you hit the e-brake just a little too hard youre toast)
i disagree. sure they can drift, but i think they're more for grip driving.
however when you talk WRC, thats a diff story :wink:
Postby Turbosolara » Tue Oct 14, 2003 2:43 pm
i agree to TRDmole, 4WD are hard to drift because the 4 wheels drives are griping too well.
for drifting, you need a rwd car (preferly FR) with high torque. The suspension need to be set differently from street
http://velocity.isfaster.com/drift/tech ... ension.htm
you also need LSD to get good traction (i learned this in hard way)
http://www.pbase.com/taiwanese_dude/240sx_crash
i believe people say lighter car (such as AE86) are easier to drift because it is light that you dont need too much power to make it drift, and it is easier to gain control over it too. There are common problems amog drifters are engine overheat, because their car goes sideway and there is no wind can go thru front mount intercooler and raidator. V-mount set up is the solution.
btw, solara drift = lose control.....
Postby MGLax13 » Tue Oct 14, 2003 5:49 pm
It's all about getting your car real low, a really negative camber and lots of tires :lol:
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby HKSV6SLE » Tue Oct 14, 2003 8:02 pm
supposedly..the best car to dritf in are cars with rear wheel drive and front engine..but than again it makes the most sense that engine with mid engine mount and rear wheel drive would theoretically be the best to drift with becuase of weight bias and such....
www.lexusnet.com
HKSV6SLE
Postby Remmi909 » Tue Nov 04, 2003 11:54 am
for FWD its called powersliding and is possible with solara's but dangerous. im saying this from experience
Remmi909
Postby Mole » Tue Nov 04, 2003 7:15 pm
FF, yes but powerslide no...
you need to be FR or MR to power slide. i think you meant e-brake slide
Users browsing this forum: No registered users and 79 guests
