SolaraGuy.com • View topic - Sway Bars on 04 SE
Sway Bars on 04 SE
Sway Bars on 04 SE
Postby cdssolara » Sun Oct 19, 2003 11:26 pm
Does anyone know if the sway bars on the new Solara SE are thicker than on the Gen 1? I thought that I read this somewhere. If so, will they fit on a Gen 1? I want to replace my Whiteline front bar with something a little less stiff, and my stock bar is not quite stiff enough (I have an 01). Anybody have any ideas about this?
cdssolara
Postby Mole » Sun Oct 19, 2003 11:41 pm
hmm.. TRD RSB, it has a 19mm setting.
oops. my bad. i highly doubt the two solaras share the same things. 2 different platforms you are talking about here.
Postby impactX » Mon Oct 20, 2003 12:26 am
TRDMole177 wrote:hmm.. TRD RSB, it has a 19mm setting.
He's talking about the front bar. Whiteline front is 24mm, stock is 17mm. I doubt new solara's bar will fit.
Why would you want something smaller anyways? You have better stability through corners now.
impactX
Postby cdssolara » Mon Oct 20, 2003 12:53 pm
Sometimes I love the effect of the front sway bar, and sometimes I get tired of the overly stiff ride. I'm just looking for a compromise between the Whiteline bar and the stock bar.
cdssolara
Postby EricSol » Mon Oct 20, 2003 4:12 pm
Me too, 19-20mm would probably be perfect.
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Users browsing this forum: No registered users and 79 guests
