SolaraGuy.com • View topic - Drilling firewall (double checking)
Postby nguyenSTX » Sun Nov 09, 2003 5:04 pm
I know this has been discussed before, and using the search i could only find pix of people who wired through the passanger side of the firewall.
I have an automatic, and wanted to double check this is the right place to drill.
<img src="http://images.cardomain.com/member_images/8/web/452000-452999/452899_6_full.jpg">
It seems obvious or maybe too obvious :-?
1999 Toyota Solara SE 4 cyl 5s-fe Auto
nguyenSTX
Postby MGLax13 » Sun Nov 09, 2003 5:12 pm
Thats not it. Look up higher and to the left a little. In that padding on the firewall, there's a peice thats scored out and it's in the shape of a propeller, about 4 inches long and an inch and a half high or so. It kinda looks like a sideways diamond. Pull it out, there's the firewall and bingo, drill there. Then look in the engine compartment and it's in a nice accesible spot to rin the wire.
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby HKSV6SLE » Sun Nov 09, 2003 5:23 pm
i'll take some pixs later of where to run the wire...
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby MGLax13 » Sun Nov 09, 2003 5:37 pm
I'm having problems drilling this hole b\c I can't get the drill to fit in that space.....GRRRR :x
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby nguyenSTX » Sun Nov 09, 2003 6:11 pm
Woo! :lol: Good thing i asked, I was about to drill it today but dint' have acess to a drill. Thanx
nguyenSTX
Postby cruze105 » Sun Nov 09, 2003 7:10 pm
yea i wanna see those picz cuz i need to run wire through my firewall
cruze105
SolaraGuy JerseyMan
SolaraGuy JerseyMan
Postby krook » Sun Nov 09, 2003 8:01 pm
MGLax13 wrote:Thats not it. Look up higher and to the left a little. In that padding on the firewall, there's a peice thats scored out and it's in the shape of a propeller, about 4 inches long and an inch and a half high or so. It kinda looks like a sideways diamond. Pull it out, there's the firewall and bingo, drill there. Then look in the engine compartment and it's in a nice accesible spot to rin the wire.
this guy's got the idea. you need to get UNDER your dash; don't just look at your brake pedal. that rubber "propellor" piece that needs to be pulled out is NORTHWEST OF THE BRAKE PEDAL. (that's up and to the left) and a drill can fit in that spot. i used a 12v Makita, so unless you're using a Dewalt drill you should be able to access it.
krook
Postby Fletch » Mon Nov 10, 2003 4:22 am
I drilled through a blank NE of the vacuum booster so that the wire comes down imbetween the accelerator and brake pedal and hides under the carpet.
I used a search on this forum to find the best recommended spot, I can't remember who or where it is posted at this point. I used a 14.4 volt dewalt and about a 6" drill bit, drilling from the engine compartment side.
2006 Legacy GT spec.B
Fletch
Fletch
Postby Yanks0114 » Mon Nov 10, 2003 2:25 pm
Heres where mine is run
Thats all the way to the back left
Postby impactX » Mon Nov 10, 2003 6:47 pm
Yanks0114 wrote:Heres where mine is run
Same... Why drill when you can use an existing one?
impactX
Postby krook » Tue Nov 11, 2003 10:55 am
^save wire. the place we're referring to is on the Driver's side. Ross ran his wire on the passenger side. if you can access that firewall from the driver's side, you can run wire in 2 minutes and save wire.
krook
Users browsing this forum: No registered users and 79 guests
