SolaraGuy.com • View topic - Diablo Racing D7 Rims?
Postby Mossy » Fri Feb 13, 2004 12:27 pm
Im looking at set of Diabloe Racing D7 rims, for my 2000 Solara, V6, I have stock ride height and plan to keep it that way....
The Rims are 18 inches and 7.5 width...
There is numerous Tire Sizes. Which would be the best?
A)215/35/28
B)225/40/18
C)235/40/18
D)245/40/18
any help in this would be grealty appreciated.. Thank You very much...
[Silverstars|Nokya Yellow Fogs|Black Clear Corners|Pioneer DEH-P7700MP|Kicker 15" CompVR|Hifonics Amp|Knuconceptz]
Mossy
Postby Jaimster » Fri Feb 13, 2004 3:17 pm
I would say 225/40/18
I've used that size on 18x7.5 size rims.
Jaimster
Postby WTF?? » Fri Feb 13, 2004 3:37 pm
^I second that
Retired... its been fun Image
WTF??
Postby nkx1 » Sun Feb 15, 2004 5:32 pm
I recommend 235/40 tires rather than 225/40. Reasons are the 235/40 more closely matches the overall stock diameter size, the extra side wall fills the wheel well better (less gap), and it will be much more forgiving with pot holes. I have 235/40's on mine, and I've driven over some nasty pot holes and never bent a rim. I think that's more than some people with 225/40's can say. If you are keeping your ride height stock, the 225/40's will look dumb. I originally had 225/40's on mine, but I exchanged them because they looked WAY too small for my stock height. Btw, be sure to get the proper offset (I believe 42mm). I got either 38mm or 40mm (can't remember which), and when I have one fat person or two normal size people in the back, the tires rub the fender wells on bumps. I know, I know, I can roll or cut the fenders, but you can avoid this by just getting the right offset. 8)
Btw, you can compare tires sizes against your stock size at www.miata.net/garage/tirecalc.html . Using this tire calculator, you can easily see that 235/40 is the way to go. Stock size for V6 is 205/60/16.
2001 SLE, Diamond White Pearl
nkx1
Postby impactX » Sun Feb 15, 2004 5:55 pm
235 will rub a lot more often than 225.
impactX
Postby boneezy » Sun Feb 15, 2004 10:34 pm
impactX wrote:235 will rub a lot more often than 225.
ditto.. since theres more width to deal
225s + good offset should do it
1999 SE-V6 5spd
160,xxx miles
boneezy
Users browsing this forum: Majestic-12 [Bot] and 56 guests
