SolaraGuy.com • View topic - caliper relocater kit??
Postby jerold » Sat Feb 21, 2004 11:10 am
...to give the big break kit impression. for those who bought the kit from eric (i think), how do you like it? how long have you had it?
jerold
2000 camry
jerold
Postby geminimouse » Sat Feb 21, 2004 11:27 am
I used mine for about 2 months when I first got it. Then took it off for the winter and just put it back on a few days ago. Brakes feel more responsive, not much of the sluggish feel in the pedal. Looks a lot better too.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby jerold » Tue Feb 24, 2004 10:33 am
that's interesting that you took it off after two months, because i was curious about the wear, since the pads don't cover the whole rotor. did you have a chance to check it over? i'm curious if the rotor wears uneven or anything?
thanks
jerold
2000 camry
jerold
Postby geminimouse » Tue Feb 24, 2004 4:45 pm
I took it off because my 17" has kumhos on them and they suck in snow. To put on my stock 16s, I had to switch back to stock rotors.
The wear is pretty even...I'll take a pic when I get the chance.
08 Accord Coupe
geminimouse
Postby EricSol » Wed Feb 25, 2004 8:19 am
I just ran my car on the 2.2 mile road coarse at Fontana with the brakes. No fade or excessive wear during my 35 minute session. I am using the Porterfield pads.
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Postby boneezy » Wed Feb 25, 2004 8:45 am
EricSol wrote:I just ran my car on the 2.2 mile road coarse at Fontana with the brakes. No fade or excessive wear during my 35 minute session. I am using the Porterfield pads.
simply amazing...
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby EricSol » Wed Feb 25, 2004 9:56 am
Amazing was.....going around a Viper inbetween 1 & 2 on the outside at 120mph. Jose was with me, even he had to smile at that!
I forgot this, my car was perfectly neutral. Stock front sway bar and TRD rear on track. I pushed before with the Whiteline front bar. Anybody want to buy a Whiteline?
1999 Solara 296 whp
EricSol
Postby all_red » Wed Feb 25, 2004 10:56 am
is it not any good? somebody said it would eliminate wheel hop, did you feel that?
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby SC V6 » Wed Feb 25, 2004 11:36 am
ill take the front sway bar!!! PM your way... what do u mean pushing? why did u not like it?
SC V6
Postby EricSol » Wed Feb 25, 2004 2:06 pm
all_red wrote:is it not any good? somebody said it would eliminate wheel hop, did you feel that?
I did nothing for wheel hop. All it did was cost me front end grip.
push=understeer
1999 Solara 296 whp
EricSol
Postby jerold » Fri Feb 27, 2004 11:05 am
i read over the original post again. does it look weird that the front is a big brake, but the rear is still the stock size? the rear already looks tiny compared to the front.
will you be/are you working on a way to relocate the rear calipers to instal a larger disc there as well? i may want to wait for that before upgrading the front.
interesting about the front and rear swaybars. i was thinking of both of those for one of my next upgrades. there is very little wheel hop now, with my intrax (cut half a coil) and tokikos. i have the 7psi with jim's heads and your exhaust. maybe the fsb would eliminate that tiny last bit of hop? do you have a CAI or one of those extensions?
thanks,
jerold
2000 camry
jerold
Postby geminimouse » Fri Feb 27, 2004 11:34 am
Here's some new pics
You'll need bigger calipers in the back to go with bigger rotors. And with the drum/disc combo i wouldn't even want to mess with it.
08 Accord Coupe
geminimouse
Postby EricSol » Fri Feb 27, 2004 4:35 pm
There isn't any oem rotors that will fit the rear that are larger then stock so no caliper relocation for the rear.
I noticed no difference in wheel hop with the bigger front bar, just understeer.
1999 Solara 296 whp
EricSol
Postby EricSol » Fri Apr 16, 2004 5:51 pm
I only have 10 kits left, more info: http://members.cox.net/solara/brakes/
1999 Solara 296 whp
EricSol
Users browsing this forum: Google [Bot] and 41 guests
