SolaraGuy.com • View topic - Cold Air Intake wrap?
Postby SolaraT » Mon Mar 01, 2004 6:32 pm
Hey guys, what is this item realy called? What key words can I search for? You know that special wrap that people put on their cold air intake setup to keep the incoming air cooler up the pipes?
Thanks,
Louis
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby mycrobyte » Mon Mar 01, 2004 6:33 pm
insulation?
2000 V6 SE
mycrobyte
Postby Mole » Mon Mar 01, 2004 7:08 pm
i used foil. but that didnt work.
heat shield?
header wrap?
Postby SolaraT » Mon Mar 01, 2004 7:17 pm
http://www.jcwhitney.com/webapp/wcs/sto ... ID=1412752
Found it! After Masive searching. :-? "Air Intake Heat shield" is the key word. Thanks guys.
Is this worth getting even if you already have an aluminum intake pipe? The more protection the better a?
2007 VW GTI
SolaraT
Postby Mole » Mon Mar 01, 2004 9:29 pm
hmm...
so is what they are advertising that i can place my arm on one side of the material and hte other side with a blow torch, i won't be able to feel a thing?
im quite weary on this, but if you want to try it out, by all means please do so and give us the results.
Postby boneezy » Tue Mar 02, 2004 9:45 am
you could try header wrap..
my IE is ghetto, so im not sure if that link above is for header wrap also
1999 SE-V6 5spd
160,xxx miles
boneezy
Aluminum and Heat
Postby Sentinel » Tue Mar 02, 2004 10:07 am
Aluminum conducts heat excellently, so Al. won't be any help if you're trying to keep your intake air cold.
Sentinel
Postby dan99solara » Tue Mar 02, 2004 10:34 pm
i had chrome intake piping on my legend, that after driving it a while i felt it and it was burning hot. so, i went to autozone and bought a can of 1200 degree black engine paint. i sprayed numerous coats until i was satisfied. it cooled down my intake a lot. the piping is a lot cooler so i hope that keeps the air colder.
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby Mole » Tue Mar 02, 2004 10:59 pm
hmm. thnx for the tip. i might do that
Postby mycrobyte » Wed Mar 03, 2004 5:16 am
I think that air intake insulation would be of some help. Because aluminum conducts heat so well, it does heat up rather quickly in the engine bay, therefore it also begins to warm the air passing through it.
On my SC's I insulated the piping with an aluminized fiberglass tape as well as isolated the filter from the engine bay. These modifications reduced my intake manifold temperature by almost 70 degrees F.
2000 V6 SE
mycrobyte
Users browsing this forum: Google [Bot] and 41 guests
