SolaraGuy.com • View topic - Carbon Fiber Hood
Carbon Fiber Hood
Carbon Fiber Hood
Postby Paladin06Greg » Fri Mar 12, 2004 7:21 pm
8) OK, I Got my Carbon Fiber hood today. I had to install the heat blanket, rubber virbration absorbers and I'll need to by two bolt inserts for the hood supports. Other then that it's awesome.
Total weight 12.5 pounds versus the OEM 30+ pounds. 8)
Paladin06Greg
Torqued Solara
Torqued Solara
Postby krawzyazn » Fri Mar 12, 2004 7:43 pm
do not put the hood supports on
Postby Paladin06Greg » Fri Mar 12, 2004 8:16 pm
:o :o Why Not????????
krawzyazn wrote:do not put the hood supports on
Paladin06Greg
Torqued Solara
Torqued Solara
Postby MGLax13 » Fri Mar 12, 2004 8:40 pm
It's too strong for the hood and it will make the outsides bow up
MGLax13
SolaraGuy Solara13
SolaraGuy Solara13
Postby Paladin06Greg » Fri Mar 12, 2004 9:02 pm
8) 8) Roger that..
Thanks
P06
Paladin06Greg
Torqued Solara
Torqued Solara
Postby krawzyazn » Sat Mar 13, 2004 12:51 am
or might make your hood crack and pop up when your driving
Postby MaxBoostSolara » Sat Mar 13, 2004 12:55 am
who made the hood u got? VIS, Fiber Images, or ???
MaxBoostSolara
Postby Paladin06Greg » Sat Mar 13, 2004 4:49 am
I got mine from FI..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SolaraT » Sat Mar 13, 2004 9:34 am
Welcome aboard! Post some pics when u finish
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby Paladin06Greg » Sat Mar 13, 2004 9:56 am
Small problem!! The hinge bolt holes are not properly spaced!!
DAMN... :x
Think, think, think..
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Jaimster » Sat Mar 13, 2004 6:19 pm
Nice car! I'm a little worried about this "UPDATE 4 Feb 04 JetChip ECU upgrade installed. The best money spent since my SC and JP Headers"
Not many would go for an ECU Jetchip, but everyone is on his own!
Good Luck! :wink:
Jaimster
Postby Paladin06Greg » Sat Mar 13, 2004 8:38 pm
Well, I was alittle concerned before I had the ECU upgrade. Now that it's done and tested. Let me say for the record "money well spent"... Hey no guts, no glory!! 8)
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Paladin06Greg » Mon Mar 15, 2004 12:42 pm
The bolts spacing issue was an easy fix. I simply got a router and enlongated the lower hinge mount holes and "BINGO" fits like a glove.
It is a sight to behold. I took a ride an had everyone rubber necking!! LOL
Paladin06Greg
Torqued Solara
Torqued Solara
Postby ToyCam » Mon Mar 15, 2004 3:23 pm
Beautiful car man!
I've got a quick question for ya. What did you have to "modify" on the strut bar to accomodate the boost gauge and the fittings that come along with it?
'92, '99, '02 V6 Camrys. Guess which one is SC'd
ToyotaNation.com
ToyCam
Postby Paladin06Greg » Mon Mar 15, 2004 5:00 pm
That one had me concerned at first. After some consideration, I took the bar to a machine and had a half moon shape cut into it. It's about half the width of the bar in depth. We finished the area, a little touch up paint, applied a rubber grommet, just for looks. I then got a 90 degree elbow, and "BINGO".. Works like a charm!!
Good luck with yours and thanks for the thumbs up. I've sunk a lot money into this car I've very happy with it.
Paladin06Greg
Torqued Solara
Torqued Solara
