SolaraGuy.com • View topic - high-flow oil filter
Postby NJsolaraguy » Wed Apr 07, 2004 3:31 pm
Does anyone know if the trd high-flow oil filter will do anything good?
99 SE AUTO
Altezzas,k&n drop-in,silverstars
Driving fast isn't always dangerous!
NJsolaraguy
Postby SC V6 » Wed Apr 07, 2004 3:53 pm
it will probably flow just about the same as the other filters... not that great im assuming.. anyone else have any ideaS?
SC V6
Postby onefiend » Wed Apr 07, 2004 5:32 pm
I dont think it matters what type of oil filter you have if you change your oil every 3,000-3,500 miles.
onefiend
Postby SolaraT » Wed Apr 07, 2004 5:35 pm
I don't have it but TRD does sell a High Flow Oil filter. This will be more beneficial for Boosted cars. I use the K&N oil filters.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby dan99solara » Wed Apr 07, 2004 6:25 pm
mobil 1
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Re: high-flow oil filter
Postby yanges » Wed Apr 07, 2004 7:30 pm
NJsolaraguy wrote:Does anyone know if the trd high-flow oil filter will do anything good?
one of the good things with the TRD filter is that besides the higher oil flow through, it traps more particulate matter and keeps the oil cleaner.....
yanges
2004 Arctic Frost Pearl Solara SE
yanges
Postby esculatus » Wed Apr 07, 2004 8:53 pm
I've always used the TRD oil filter (the red imported one) with Mobile synthetic oil. Never have any problem. It's a bit expensive (~$25). but I think spending ~40 per oil change is better than go to the dealership and spend 25 on ordinary oil and filter.
esculatus
Postby Mole » Wed Apr 07, 2004 8:54 pm
dan99solara wrote:mobil 1
i second that
Postby Fletch » Thu Apr 08, 2004 4:56 am
SAE 30 & Fram
2006 Legacy GT spec.B
Fletch
Postby Whatever » Thu Apr 08, 2004 6:48 am
solarat wrote:I don't have it but TRD does sell a High Flow Oil filter. This will be more beneficial for Boosted cars. I use the K&N oil filters.
how do you like the K&N oil filters?
Whatever
Postby yanges » Thu Apr 08, 2004 9:16 am
esculatus wrote:I've always used the TRD oil filter (the red imported one) with Mobile synthetic oil. Never have any problem. It's a bit expensive (~$25). but I think spending ~40 per oil change is better than go to the dealership and spend 25 on ordinary oil and filter.
i think the white TRD is sufficient.....it is high flow also.....and only about $10!
i thought the red one was for racing?
yanges
yanges
Postby esculatus » Thu Apr 08, 2004 9:39 am
hmm the dealer told me the red one is directly imported from Japan while the white one is made here. So now I am confused. Maybe you're right that the red one is an overkill...
esculatus
Postby yanges » Thu Apr 08, 2004 10:19 am
esculatus wrote:hmm the dealer told me the red one is directly imported from Japan while the white one is made here. So now I am confused. Maybe you're right that the red one is an overkill...
i am sure both TRD filters are good, regardless where they are made....
here is a link with good info on the white filter:
http://www.brandsport.com/trd-00602-90915-004.html
yanges
yanges
Postby B_Master_Flash » Thu Apr 08, 2004 2:03 pm
:2gunfire:
Fletch wrote:Fram
B_Master_Flash
Postby xtychx » Thu Apr 08, 2004 2:16 pm
K&N and Mobil 1 filters are made by the same company (Champion Labs), they just have different purposes. The K&N filter is has a slightly higher flow velocity than the mobil 1, but the mobil 1 traps a slightly higher micron level of particles. As such, K&N is more suited to those that drive their car hard, while the mobil 1 filter is better for those who drive more gently and benefit from better filtering. Personally, I used the K&N.
-xtychx
xtychx
