SolaraGuy.com • View topic - Tokicos spinning, can't tighten top nut
Postby pythonjosh » Sun May 23, 2004 1:58 pm
My tokicos are hella rattling and when I was installing the top rod just kept on spinning on all 4 so the top nut couldn't be tightened. My friends (Honda ppl) said their tokicos have a hex key for the shaft so it doesn't spin. Not true for my car. How did you guys tighten your tokicos? This has been annoying me and confusing me since I installed them. Thanks,
Josh
pythonjosh
Postby Mole » Sun May 23, 2004 3:27 pm
some have the hex at the top, and others have a cut through the shaft, near where the nut tighten downs on.
you can use an open end wrench to secure the strut rod, then tighten the nut.
Postby impactX » Mon May 24, 2004 2:05 am
impact wrench
How else did you loosen the nuts on the old strut?
impactX
Postby pythonjosh » Mon May 24, 2004 3:19 am
impactX wrote:impact wrench
With a rachet. And I don't see how an impact wrench would stop the shocks from spinning around. Today I jacked up the front and put some gloves on and grabbed the shock to hold it still. Worked for the front too. Will try to tackle the rear shocks tomorrow. Think I'll need 2 people. Later,
Josh
pythonjosh
Postby swimshady906 » Mon May 24, 2004 3:40 am
The impact wrench will apply alot more tq instantly with less rotational bias
02' S2000 Silverstone
swimshady906
Postby impactX » Wed May 26, 2004 11:36 pm
swimshady906 wrote:The impact wrench will apply alot more tq instantly with less rotational bias
Exactly.
impactX
