SolaraGuy.com • View topic - 4 piston calipers up front?
Postby swimshady906 » Mon May 31, 2004 1:06 am
The new 4 runners, some of them have 4 piston calipers up front and i have yet to look into braket sizes but if they can stop a 4300lb truck they sure as hell can stop a car that weights 1/2 ton less right? Is that logical?
02' S2000 Silverstone
swimshady906
Postby Jackass-Jeff » Mon May 31, 2004 7:24 am
Yes, but the size of the rotor also makes a difference.
Ericsol's big brake kit may only be a larger rotors w/ a same ghetto 1 piston (right? or is it 2? lol) oem caliper. But since the rotors spins, and the brake caliper is pushed out more, it provides some more stopping power (surface area used) instead of having a stronger brake that would grip it a lot harder.
1GR-FE ftw!
Jackass-Jeff
Postby swimshady906 » Mon May 31, 2004 12:06 pm
I want more stopping power and a bigger surface. I bought eric sol's kit and now i want more :D
swimshady906
Postby Mole » Mon May 31, 2004 11:21 pm
aren't 4runners 6lug?
Postby swimshady906 » Tue Jun 01, 2004 12:45 am
The Bogey Man wrote:aren't 4runners 6lug?
I guess the might be, but would that make a difference? The calipers dont attach to the hub through the lugs... atleast mine dont :o mebbe thats the problem :D
swimshady906
Postby Mole » Tue Jun 01, 2004 9:13 am
how are you going to make a rotor that is made for 6 lug fit through something that is made for 5 lug?
i was thinking of rotors not calipers. haha
hmm so to upgrade to bigger calipers. you would need to make a adaptor bracket similar to the one eric sol has done.
Postby swimshady906 » Tue Jun 01, 2004 11:03 pm
Yes. I pretty much just want to experement and test things to find out what will make stopping power better without acctually just buying a real kit i guess :roll: If i evre find something good, ill let evreyone know.
swimshady906
Postby Solara562 » Tue Jun 01, 2004 11:42 pm
if you are gonna try something like that, try using the supra tt calipers.
Solara562
Postby impactX » Wed Jun 02, 2004 12:49 am
Want better braking power? Upgrade the lines, pads, and tires.
The calipers aren't going to help you all that much on the streets.
impactX
