SolaraGuy.com • View topic - Painted my calipers
Painted my calipers
Painted my calipers
Postby Blazed04 » Thu Aug 12, 2004 2:48 pm
I dunno...i got bored a few days ago and decided to paint my calipers. There were some threads about this a while ago but i dont know if anyone actually went through with painting them or not. I just wanted an eye catcher (besides the chrome) to set the car apart from all the stock Gen2's on the road. Take a look. Image Image
Lunar Mist '04 SE Sport V6
2001 GSXR 750
Blazed04
Postby got sport » Thu Aug 12, 2004 3:34 pm
Sweet. Can you explain how you painted them? Like a DIY tutorial. Thanks.
<b>'04 V6 SE Sport -Black</b>
http://www.cardomain.com/id/gotsport
got sport
Postby Blazed04 » Thu Aug 12, 2004 10:20 pm
All i did was took my wheels off, taped off the rotors and all other parts that i didnt want over-spray on (including my fenders & quater panels) just used some brake cleaner on the caliper to clean it off, and sprayed it with the red caliper paint. Did 3 coats, it dried it no more than 2 minutes each coat. Simple. The longest part was taking off and putting on my wheels.
2001 GSXR 750
Blazed04
Postby mattyboyl » Fri Aug 13, 2004 4:12 am
Sweet job Blazed. The calipers look so small with those dubs. I have done this to the GT in the past and I had to reapply every summer. The extreme heat due to stopping heats the brakes up and the front brakes start cracking and peeling after a while. I think the cold weather coupled with the extreme heat of the brakes cause the cracking especially. If you don't buy that, just look at the streets which go through constant hot and cold temps. Even the pipes burst after being expanded and going back to normal size due to temp. fluctuations. Just giving a heads up. I have been thinking of doing that myself, but I don't know if I want to deal with the yearly maintainence.
mattyboyl
Postby Blazed04 » Fri Aug 13, 2004 8:42 am
what kind of paint did you use? was it caliper paint, or just a high temp paint??
2001 GSXR 750
Blazed04
Postby mattyboyl » Fri Aug 13, 2004 10:13 am
I used porshe caliper paint. This was the enamel stuff the first time then I used the spray caliper paint the second time around. Either way, unless you powdercoat the rotors, they will crack and peel. This isn.t a problem because you just touch them up as needed as oppossed to starting over.
mattyboyl
Postby Jai_Jai_Binks » Fri Aug 13, 2004 10:17 am
Looks good. now get some nice high temp caliper decals. THat what i plan on doing when i redo my calipers.
Postby cklinh » Fri Aug 13, 2004 10:36 am
Jai wrote:Looks good. now get some nice high temp caliper decals. THat what i plan on doing when i redo my calipers.
Me too. Actually, that's what is holding me up... I haven't been able to find "Solara" decals.
cklinh
Postby Jai_Jai_Binks » Mon Aug 16, 2004 9:36 am
No one makes em, unless we make a gb here..then it might be available...the only ones are crappy toyota logo, TOYOTA and TRD (which i what i was thinking about).
Postby mtodde » Mon Aug 16, 2004 10:20 am
mattyboyl wrote:I used porshe caliper paint. This was the enamel stuff the first time then I used the spray caliper paint the second time around. Either way, unless you powdercoat the rotors, they will crack and peel. This isn.t a problem because you just touch them up as needed as oppossed to starting over.
What kind of enamel did you use? I've been thinking about buying the G2 kit.
Thanks
2004 Solara V6 SLE
Lunar Mist Metallic
2 time Solara owner (1999 SE V6 MT)
http://www.cardomain.com/memberpage/648891
mtodde
Postby mattyboyl » Mon Aug 16, 2004 11:47 am
I can't remeber but I do know that I used two different brands made for calipers and they both started to crack and peel. Thyey just need mainatainence about every 6mos- year depending on weather and driving habits. If you do alot of racing and are hard on the brakes and heat them up, more than likely they will peel faster than someone who just uses their car tfor daily driving and doesn't stop at 80-100mph+!
mattyboyl
Postby vuuuuu » Mon Aug 16, 2004 8:14 pm
I've done that with my prelude before, but I used high-temp resistant paint so that cracking and peeling didn't occur. They lasted for about 2 years - after that point they just got dirty and I resprayed them.
Anyway, on a side note: Did you lower your car? If not - that is perfect! Great size wheels for the car. I'm definitley getting 20"s if you didn't lower it. :)
2004 SLE V6 Lunar Mist Solara
vuuuuu
Postby dvdchris45 » Mon Aug 16, 2004 9:31 pm
Question,
I herard that its recommended to change the brakes when you get new rims, cuz I'm assuming you'll need some more stopping power to those bigger rims and tires. Is this true?
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby Mole » Mon Aug 16, 2004 10:29 pm
its recommended you change brakes when they wear down!
other than that the only other time you need to upgrade your braking power is when you gain more power and speed.
it is always a plus to upgrade a brake system.
