SolaraGuy.com • View topic - Small annoying rattling noise inside cabin
Postby gnegroni » Sun Feb 22, 2009 6:45 pm
Well guys, my car has about 70k miles, but already developed a lot of noise inside the cabin. I have to work the speaker area for some plastic noise as well as the drive seat belt extender squeak. Its the plastic way!
However, what really bothers me is a small noise that only appears when revving the engine hard (4500+ rpm). It seems as if its coming from under the dash, left side. I've felt it for a while now, but I'm beginning to hear it becoming more noticeable than before.
Any ideas? Maybe the fuse panel area has gotten loose? Should I look for anything?
gnegroni
Postby Ilovemylara » Sun Feb 22, 2009 7:05 pm
wow i've noticed that too.... it vibrates with the roar of the engine.
Postby gnegroni » Sun Feb 22, 2009 10:02 pm
I don't see how, but I'm going to have to take a deeper look in the meantime. I know the big panel under the steering wheel is vibrating at very low rpms (manual car low rpm), so I'm gonna check that too.
gnegroni
Postby (K) » Sun Feb 22, 2009 11:23 pm
Try having someone revving the engine while you look under the hood. That way you can see if anything is moving more than it normally would. I know it's almost impossible to do by yourself because we don't have access to the throttle from under the hood...
(K)
Postby Ilovemylara » Mon Feb 23, 2009 12:27 am
(K) wrote:Try having someone revving the engine while you look under the hood. That way you can see if anything is moving more than it normally would. I know it's almost impossible to do by yourself because we don't have access to the throttle from under the hood...
perhaps the throttle arm on the throttle body??
Postby lilm » Mon Feb 23, 2009 1:09 am
lol
lilm
Postby (K) » Mon Feb 23, 2009 7:39 am
vvt-i has no throttle cable. Unless I completely missed something while looking under my hood.
(K)
Postby Sparky5e » Mon Feb 23, 2009 10:30 pm
I tried to rev the rpm under the hood instinctively when jump starting my jeep. Felt pretty stupid LOL
07 SLE Convertable
Blue Streak Metallic
Sparky5e
Postby PXLpainter » Sat Feb 28, 2009 5:36 pm
I've just added louder rattles and squeaks to mine, with a suction cup-mounted lic plate bracket, radar detector and iPhone holder... I just turn up the tunes louder if the top isn't down - otherwise air and exhaust noise cover up any annoying squeaks and rattles! ;)
