SolaraGuy.com • View topic - Supercharger Belt Tension
Postby grnsolara » Fri May 09, 2008 12:36 pm
I am having my first supercharger belt change for my 1mz-fe 2000 solara. If I'm using a 6 lb. pulley instead of the stock, does this alter the tension setting of the belt? I'm going to have a shop do it since I don't trust myself enough, but needed to know the exact torque when installing the belt. Any help is appreciated.
I read forums more than I talk. /shame
grnsolara
Postby Dawgz » Fri May 09, 2008 12:41 pm
120lb should be the tension on the BELT.
Postby akora12 » Fri May 09, 2008 12:43 pm
No matter what size of pulley you're using, the belt should initially be tensioned to 120 lbs. After running the engine for a bit, it should drop between 70-90 lbs. You may need a shorter belt if just switching to the 6 lb. pulley in order to get the correct tension on the belt.
Postby Dawgz » Fri May 09, 2008 12:45 pm
But, if u have the dynamic tensioner, u shouldnt have to worry about the tension on the belt
If u have the older setup however....it needs to be at 120lb on the belt...but a good mechanic can tension and check it by hand.
Postby grnsolara » Fri May 09, 2008 2:48 pm
Thank you. Where would I obtain a shortened belt specifically for this setup? I'm just using a standard setup...had this installed about 3-4 years ago.
grnsolara
Postby akora12 » Fri May 09, 2008 4:29 pm
Stock length of the belt is 87.5mm for the s/c w/o an automatic tensioner. That should also work for a 6 lb. pulley. You might be able to find one at a local auto parts store, but I had to order mine online. I currently have a goodyear gatorback, but dayco works.
Return to Forced Induction
Users browsing this forum: No registered users and 73 guests
