SolaraGuy.com • View topic - um...what?
um...what?
Re: um...what?
Postby lemegacool » Thu Jan 20, 2011 3:40 pm
ohhh no i wanted to see another holset powered 1mz... well this is not bad either lol ;) let me know how the fic is runnig as i choosed that too for my fuel ignition management ;)
thumbs up ! look real good!
1994 camry v6 5 speed swapped
custom m90 blower in progress
cardomain: http://www.cardomain.com/ride/3872430
lemegacool
Re: um...what?
Postby 1gSE » Thu Jan 20, 2011 9:35 pm
Believe me, I would have looovvveeeddd to put the holset on, but it just wasnt going anywhere. Maybe if I knew how to weld it probably would have been done by now lol
Solara-M62 @ 5.5psi
1gSE
Re: um...what?
Postby ToyoSolV6 » Fri Jan 21, 2011 7:21 pm
nice dude and welcome to the boost club :evilbat: theres no turning back now. Im sure you will man handle the Z and the ms3, if the cooper s has work those things are a bit scary when their running high boost and a larger charger those little things scream.
but nice 5.5psi is good thats where im at and debating to go onto 6psi. as of now i need meth to be safer. but the time will come when i say ehhh 9psi here i come lol
Re: um...what?
Postby 1gSE » Fri Jan 21, 2011 8:57 pm
It's hanging out at 6psi quite often. Now that I got the meth working, its set to kick in at around 4psi. I can feel it bog down at lower rpm. On a long 2nd and 3rd gear pull, boost actually peaked at 7 psi on meth :o Intake temps were down to low 90*, it even dropped as low as 88*. Short term fuel trims are around -2.3 to +2.3% at idle and cruise. It runs great!
Solara-M62 @ 5.5psi
1gSE
Re: um...what?
Postby mig0s » Fri Jan 21, 2011 9:16 pm
How's the MPG with the supercharger? Any significant differences?
mig0s
Re: um...what?
Postby 1gSE » Fri Jan 21, 2011 9:19 pm
Not sure yet, I've only put about 60 miles on it since the install, but I'm sure there's gonna be a pretty good drop with my lead foot
Solara-M62 @ 5.5psi
1gSE
Re: um...what?
Postby lemegacool » Sat Jan 22, 2011 9:14 am
how can you not have a lead foot with a SC lol i just swapped a 5 speed and i go on it even more than before lol
lemegacool
Re: um...what?
Postby 1gSE » Sat Jan 22, 2011 11:22 am
Lol I know right. All this WOT really does a number on the meth tank though. Its a half gallon tank and I emptied it in 3 runs. Of course these were pretty long pulls, but still. I might dilute the windshield washer fluid with more water so I don't have to keep buying as much
Solara-M62 @ 5.5psi
1gSE
Return to Forced Induction
