SolaraGuy.com • View topic - Max Tires Size for 19" offset 40 ???
Postby tolik1980 » Sat Aug 09, 2008 4:50 am
Im planing to upgrade my rims
i wonder if these tires will fit my car :
245/40R19 rear
235/40R19 front
My car is lowerred with TRD springz btw.
Anybody running such tires ?
tolik1980
Postby philosophicaljt » Sat Aug 09, 2008 6:53 am
www.miata.net/garage/tirecalc.html
^^its a great site. It will let you know how everything will size up.
2004 Solara SLE V6
Search
philosophicaljt
Postby tolik1980 » Sat Aug 09, 2008 8:14 am
this calculator only show the difference between stock wheel and new whell and this is not the answer to my question
tolik1980
Postby LostSoul » Sat Aug 09, 2008 8:47 am
LostSoul
Postby philosophicaljt » Sat Aug 09, 2008 9:00 am
If the outside dimensions are exactly the same or smaller, then yes it will fit. Try a search :)
2004 Solara SLE V6
Search
philosophicaljt
Postby PXLpainter » Sat Aug 09, 2008 10:14 am
With 245s you may need to roll/trim your rear fenders, but that's the size I plan to put on mine after I get some new rims (someday!) ;)
Postby tolik1980 » Sat Aug 09, 2008 1:22 pm
what about the front wheels will they roll clean if i turn the steering wheel to the end ?
tolik1980
Postby PXLpainter » Sat Aug 09, 2008 2:18 pm
tolik1980 wrote:what about the front wheels will they roll clean if i turn the steering wheel to the end ?
Prolly roll okay but depends on how lowered you are. Also if you're driving hard in a corner and hit a big bump you'll probably still scrape.
Postby tolik1980 » Sat Aug 09, 2008 11:38 pm
im lowered with trd springz is it too low ?
tolik1980
Postby PXLpainter » Sun Aug 10, 2008 1:19 am
Yours won't be as low as mine - but you're going up to 19" so like I said, it might rub while in motion turning tight corners.
Things working against me:
• -30 offset rims
• about an 1/2" lower than TRD springs
• I am a fat ass that drops the car another 1/2" ;)
So I've currently got 225/45/18s on my ride (235's would be perfect dia and width on front if my offset was 40-42)
Seriously though, check out the calculator here and use the OEM specs as your guideline (215/55/17 - 17x7.5 40os)
http://www.rims-n-tires.com/rt_specs.jsp
MUCH better than the goofy Miata tire calc thingy and gives you fitment info with offsets, etc... :up:
Postby tolik1980 » Sun Aug 10, 2008 1:45 am
yeah thanks for the link
one question remains xxx/35 or xxx/45 tires ?
tolik1980
Postby PXLpainter » Sun Aug 10, 2008 11:20 am
tolik1980 wrote:yeah thanks for the link
If you're planning on rolling on 19s then you're going to need xxx/40s if you want the closest to correct dia. If you actually use the calculator in the link I gave you then you'd see that as well. ;)
