SolaraGuy.com • View topic - 70k tune up???????
70k tune up???????
70k tune up???????
Postby LatinUSMC » Tue May 10, 2005 12:00 am
im thinking of doing the 70k tune myself :D ......what woul you guys advise???? :oops: or should i just take it some where$$$$??? :evil: :roll: thinking of buying All spark plugs , filters,etc online/autozone .......i have tools....but not sure :o :roll: im in the north san fernando valley...HELP!
LatinUSMC
Postby Turbosolara » Tue May 10, 2005 12:02 am
toyota adviced replced change spark plug, tranny flush, radiator flash and timing belt and water pump at 60k service. i am not sure if you want to mess with the stuffs by yourself
Postby bassthrive » Tue May 10, 2005 6:47 am
Turbosolara wrote:timing belt and water pump at 60k
really??? haynes manual says 90k for the belt and nothing about the water pump.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Jon11582 » Tue May 10, 2005 6:54 am
I agree with bassthrive. Belt at 90k is fine for our cars, and there shouldnt be a problem with the pump if you maintain the coolant right.
Plugs, tranny, and coolant would be on my list for 60k, all DIYable if you know what your doing. Should be the second time you do the coolant flush (Every 30k).
2000 Black Solara SE
Jon11582
Postby Jackass-Jeff » Tue May 10, 2005 8:53 am
60K
Auto Transaxle Fluid (ATF) 4 qts, I believe
Oil change (duh)
Coolant (30K intervals)
That's all... but I do recommend getting Toyota ATF fluid and Coolant... filters can be bought elsewhere... if you get the wrong fluid, you're boned.
Depending on which spark plugs you have, you may have to change them... some were 90K and some were 60K... check your manual. I'm too lazy to check for you... but I think it's 90K if it's the same ones in the ES300
1GR-FE ftw!
Jackass-Jeff
Postby LatinUSMC » Tue May 10, 2005 8:43 pm
thanks for the info :lol: .... so its due at 60k...huh??? DOUHHH :oops: :o
LatinUSMC
Postby Jackass-Jeff » Wed May 11, 2005 8:36 am
LatinUSMC wrote:thanks for the info :lol: .... so its due at 60k...huh??? DOUHHH :oops: :o
if you missed it... you may want to flush it... at least, that's what I did when I missed my first trans fluid change.
1GR-FE ftw!
Jackass-Jeff
thanks
Postby LatinUSMC » Wed May 11, 2005 9:55 pm
turbo i got in contact with your boy Dave ...seem like he knows his stuff...ill get back to him later when his hand gets better :)
LatinUSMC
