SolaraGuy.com • View topic - Anyone Got These Wheels?
Postby Mr_Chunks » Fri Jul 28, 2006 2:44 pm
Enkei PKR
17x7 or 7.5 Width
114x5 bolt pattern ( gen1 solara )
black with polish lip
I want some really bad and im beginning to save up for them. Whose got them or something that looks similar?
Mr_Chunks
Postby WTF?? » Fri Jul 28, 2006 2:45 pm
StockSolara used to have a similar style on his, but they were 18's.... now theyre owned by some camry guy (camry101?)
Retired... its been fun Image
WTF??
Postby Sap Z » Fri Jul 28, 2006 3:16 pm
17s wont look good. the lip takes away an inch-
SapZ
V6 SE DWP
Sap Z
Postby Mr_Chunks » Fri Jul 28, 2006 3:54 pm
but 18s would be bad with a 1.75" drop
which is what im gonna be rockin about a week after purcashing these rims
id hafta get like 35 series tires
which is too damn skinny for the kind of racing i do.
i need 40 or 45 series rubber
Mr_Chunks
Postby indiglosolara » Fri Jul 28, 2006 4:11 pm
Mr_Chunks wrote:but 18s would be bad with a 1.75" drop
With 18's you should run 40 series tires.. not 35. That would make the diameter if the wheel small thens tock throwing your speedo off.
I am running 19 with 35 and lowered about 1.7" and dont have problems.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Mr_Chunks » Fri Jul 28, 2006 4:19 pm
if i run 18 with 40size then 1.75 drop and 1.6 drop in back ( setting my suspension to have a heavy 12 in the back ) then wouldnt I rub?
Mr_Chunks
Postby indiglosolara » Fri Jul 28, 2006 4:22 pm
Mr_Chunks wrote:if i run 18 with 40size then 1.75 drop and 1.6 drop in back ( setting my suspension to have a heavy 12 in the back ) then wouldnt I rub?
depending on the offset of wheels you wont. if its 18x7.5 run a +42 or +40 offset with 225/40/18 tires and you will not have problems at all.
If you want to talk about a heavy trunk mine was heavy as hell. My drop in the rear was 1.5" and with my custom trunk it was almost 2" drop. I have no gap between the tire and fender.
1.75 and 1.6 is nothing. You will still have a 2 or 3 finger gap in the rear.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby that1mexguy » Fri Jul 28, 2006 6:35 pm
man dont go for 17s, you'll regret it... i have 18's and wish I had 19's
that1mexguy
Postby indiglosolara » Fri Jul 28, 2006 6:39 pm
that1mexguy wrote:man dont go for 17s, you'll regret it... i have 18's and wish I had 19's
You can buy my 19's.. hahhaa
indiglosolara
Solara 2 xB
Solara 2 xB
Suggestion
Postby JMSinMaryland » Fri Jul 28, 2006 7:02 pm
The perfect plug and play fit is an 18x7.5 with a 45 mm offset riding on 225/40 18's. I put in my vote for Yokohama Avid H4s in that size and get dropped first. Jon.
JMSinMaryland
Postby Solorange » Fri Jul 28, 2006 9:54 pm
Yo Chunks I do like the choice of rims, I think they will look hot, but do get 18's. Sap Z is right the lip makes them look smaller. Look at my car for an example.
Postby StockSolara » Fri Jul 28, 2006 11:49 pm
Yeah I used to have a similar set of rims. . . you may check them out on my cardomain site. . . too bad you live in Harbor City. . . If you were close to San Jose I would have told you to stop by America's Tire Co and I could have got you a good deal on those wheels and tires
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby PXLpainter » Sat Jul 29, 2006 12:10 am
I like 'em - but go with 18s on that Gen 1 :)
Postby Mr_Chunks » Sat Jul 29, 2006 12:41 am
man
the consensus seems to be 18"
im just PARANOID about rubbing
BTW speaking of lowering does anyone have ground controls? What kind of struts should i run with ground control to maintain a like stock ride but stiff turning?
Mr_Chunks
Postby trdkamuri51o » Sat Jul 29, 2006 2:23 am
if you dont wanna roll, 42+ is the best.. 19x7.5 righ there.. or 19x8 38+ etc.
check indiglosolaras faq.. he has owned more wheels than anyone here
go with 18s at the minimum though.. 17s are too small looking 225/40/18 is the perfect tire size to keep from rubbing the strut & the fender well
trdkamuri51o
