SolaraGuy.com • View topic - wtb: black gen 1 headlights/corners
Postby woa_its_j3ff » Sat Dec 08, 2007 12:29 pm
title says it all..
if anyone has some up for sale or can hook me up with a set, let me know.
( i woulda looked on ebay but dont have an ebay account and figure id try here first anyhow )
Re: wtb: black gen 1 headlights/corners
Postby Mr_Chunkz » Sat Dec 08, 2007 5:57 pm
woa_its_j3ff wrote:title says it all..
i hope you plan to retro cause black house gen1 lights with HID creates a beam pattern that is far beyond piss poor
those headlights were the very reason i went thru with my retrofit.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby SleeperSolara » Sat Dec 08, 2007 7:13 pm
HID retro or bust. :lol:
Postby woa_its_j3ff » Sat Dec 08, 2007 11:31 pm
Worse than stock>? im so curious as to how blacked headligths are worse than stock since all that is changed is the housing cover and not the reflector..
Postby Ruski » Sun Dec 09, 2007 7:45 am
Yes worse then stock. the light output sucks ass.. Unless you wanna do a retro like people said
Postby akora12 » Sun Dec 09, 2007 9:26 am
I painted the factory headlights and the light output didn't change at all, plus they are much easier to adjust from what I've heard. It's a bit more work than just buying the aftermarket ones, but worth it IMO.
Postby CamryOnBronze » Sun Dec 09, 2007 10:21 am
The light output is slightly worse, but in my case it wasnt something I couldnt live with. The angling adjustment is the same, so i dont know how its more difficult. You will notice however that the durability of the angling screws is not very good, but my stock ones were broken as well so i dont think that is a huge factor. The beam pattern will just be a little spottier, that is the only real difference.
Postby akora12 » Sun Dec 09, 2007 12:27 pm
^^^ I may have described that wrong. I didn't mean the adjustment is easier on OEM headlights, but I've heard they break less easily. Regardless, either way you go I'm sure it will be fine. Personally, I don't think the light output or durablity on the OEM headlights is that good anyways.
