SolaraGuy.com • View topic - 2 Pix
2 Pix
2 Pix
Postby Mr_Chunks » Fri Jun 30, 2006 6:32 pm
Experiemented with engine enamel. Painted it blue originially with clearcoat on top but didnt like it so i decided to go to aluminum metallic with clear coat. Painted just the valve cover and battery tie down for starters
also got a red top batt. Just a question tho: How do you other gen1 guys secure your redtop down? I got the tie down across but that rod that pushes into the back between the batt and airbox wont stay. The bolt only goes down so much and its about 4mm shy of touching the batt. Its secured to some extent but not as much as I want it to be.
Anyway heres 2 pix of my engine bay
Mr_Chunks
Postby Astro » Fri Jun 30, 2006 9:02 pm
The paint looks nice. For the battery, my Optima came with a plastic tray that went under the battery to lift it up to stock battery height. I'm guessing yours didn't come with one.
Postby Mr_Chunks » Sat Jul 01, 2006 3:11 am
Astro wrote:The paint looks nice. For the battery, my Optima came with a plastic tray that went under the battery to lift it up to stock battery height. I'm guessing yours didn't come with one.
actually it came with a lid and group 74 adapters
i snapped the lid to the underside and the battery tie down and rod fit okay but the positive terminal couldnt stretch. As it is the battery sits crooked in there to let the positive terminal reach.
i went to pep boys and they said they could sever the terminal and extend the cables but that seems risky/expensive. What if they screw up my positive terminal for good, you know?
I tried reverse mounting the battery but it still wouldnt reach and im pretty sure reverse polarity is a horrible idea ( didnt try it, dont think i should ).
my choices are a bit limited :(
Mr_Chunks
Postby indiglosolara » Mon Jul 03, 2006 7:53 am
You know Optima made a red top Group D35 that is a direct bolt on for the Solara. You need the tray to raise it up and its bolts in like stock. Thats what I have..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Mr_Chunks » Mon Jul 03, 2006 12:49 pm
-_- I was told to get the 34R battery
either way its bought now and my old core was returned so Im probably gonna have to extend the terminals and find a way to make it fit.
Mr_Chunks
Postby SleeperSolara » Mon Jul 03, 2006 1:17 pm
Looks nice man.
Postby Whatever » Mon Jul 03, 2006 4:31 pm
well you can always try Loctite
Whatever
Users browsing this forum: No registered users and 89 guests
