SolaraGuy.com • View topic - Meth-Injection Kit Install
Postby Akfahad » Sun Aug 05, 2007 5:48 pm
Thanks to Greg for opening my eye's to this...
Here's pics of the install, took all weekend. Hardest thing to do was to figure out where the hell to mount everything. Plus we needed some more 1/4" tubing.
FYI, for whoever wants to do this for this particular meth-injection kit from Snow Performance (Stage 2 MAF Boost Cooler), the 5 volt wire that you need to tap into is Pink (there you go Milt) and since you need to find a 12 volt key on source, I used the EFI (Electronic Fuel Injection) fuse from the fuse panel in the engine compartment.
Ok, so here's the pics.........
Pump install (driver's side wheel-well)
Taping into the windshield washer resevoir. The kit comes with an extra tank, I just didn't have room and I didn't want to put it in the trunk.
Boost Computer mounted on the fuse panel
Nozzle placement on the intake.
Postby woa_its_j3ff » Sun Aug 05, 2007 5:53 pm
that looks really cool man but i'm just wondering,
what exactly does meth-injection do? is it like something related to the principles of nitrous?
Postby Akfahad » Sun Aug 05, 2007 6:06 pm
Jeff - straight from Snow Performance:
"In gasoline engines, as with any intercooler, this suppresses detonation so more power producing boost and timing can be utilized. Water, with its high latent heat of vaporization cools the intake charge and combustion. Methanol cools the charge and combustion but also acts like an extremely high octane fuel (some researchers claim as high as 120 octane) as well as adding more oxygen to combustion."
Postby SleeperSolara » Sun Aug 05, 2007 6:35 pm
Looks clean man.
Postby Midias » Sun Aug 05, 2007 6:38 pm
Looks good
is that something you run all the time or just when you crank up the boost? Also how long does each tankful last?
Postby Akfahad » Sun Aug 05, 2007 6:58 pm
^^you can adjust the little computer to tell the pump when to come on. taping into the MAF sensor wire allows to change at what voltage to bring it on (in my case, adjusting the voltage based on what boost i'm reading). It'll only come on when i really get on it and based on how aggressive you drive, determine's how much you have to fill up the reservoir.
This is also something you'll need to dyno, something I haven't done yet.
Postby Dawgz » Sun Aug 05, 2007 7:05 pm
i'd do something like that but i think its a tad bit to risky. Something about shooting water/methanol into my engine doesnt sound to pleasing to me =\
NICE WORK THO! Great pics!
post Dyno Charts when u get them.
Postby ---CAMRAZY--- » Sun Aug 05, 2007 7:33 pm
Great work Josh!!!
Dyno time!!!!
Postby Ruski » Sun Aug 05, 2007 9:15 pm
Nice .. lets get that bad boy dyno d
Postby PXLpainter » Sun Aug 05, 2007 11:23 pm
Damn - this is some hard-core shiz right here!! :up: Kewl!! :D
Postby ptballer » Mon Aug 06, 2007 7:59 am
What mixture of methanol are you running or are you just spraying water?
ptballer
Postby SC V6 » Mon Aug 06, 2007 8:37 am
my issue with Meth injection is that if you tune according to the injection system working correctly, then if the methanol tank gets empty, or pump shuts off, you blow your motor or if not that do some heavy damage.
jmo
SC V6
Postby Akfahad » Mon Aug 06, 2007 3:39 pm
I'll be running a 50/50 mix, which I'll have reduce my A/F ratio numbers by .5 as a result. I can also play with my timing, but never done that before.
And I understand about the whole reservoir going empty and now all of a sudden you could start doing damage, but I figured I'd just keep an extra gallon in the trunk in case I ever get that "low" light. Plus I can tell the pump when to come on (mine will come on at about 1psi to 6psi), so if I know the tank is empty, I'll just make sure I don't hit boost.
Postby Akfahad » Sat Aug 11, 2007 11:25 am
just got back from the dyno shop....made an extra 15 HP and an extra 20 lbs. of TQ and the numbers kept growing with each pull, but we stopped after our 3rd pull since it was hot ~ 95. Didn't need to change the A/F ratio at all, it was pretty much dead-on and third gear pulls ridiculous now. I had him record my highest knock ping at full throttle, highest it got to was 63, which is awesome considering I use to be sitting around 30 at idle with this heat.
Postby Eye8Pussies » Mon Aug 13, 2007 8:37 pm
awesome numbers...and pretty much as expected.
So did you use a boost solenoid to activate the injection then? And did you end up using the MAF sensor wire at all?
