SolaraGuy.com • View topic - Custom Y-Pipe installed...um yeah
Postby bigbirdSCed » Wed Feb 27, 2008 11:30 pm
ok so, install was a pain because the previous owner had the exhaust up to the exhaust manifolds welded as one piece (including the factory Y-pipe) so after cutting and welding in a flange to mout it, this is the result(plus an exhaust leak that i have to take back to fix).
i think it sounds like crap personally, i was expecting a change but not so drastic. performance is very nice says my ass dyno, low end power has suffered but top end is better, ill find out how good in a couple weeks it think.
before:
http://youtube.com/watch?v=jMkuWCy7jtk&feature=related
after: :-?
http://youtube.com/watch?v=rgXCaNxhBUI
in gear outside(some tire spin too):
http://youtube.com/watch?v=SMz74qtl0EQ
in gear inside moderate acceleration:
http://youtube.com/watch?v=Wre7APF0qVQ
its actually louder then that, the mic was pointed foward so it got more S/C then exhaust.
the y-pipe(perviously owned by mzfe5speed)
bigbirdSCed
Postby woa_its_j3ff » Wed Feb 27, 2008 11:42 pm
either way it sounds good, but personally I think it sounded better before the y-pipe.
great lookin car man.
Postby Dawgz » Wed Feb 27, 2008 11:43 pm
How does that sound like ass? i think it sounds sweet.
Postby Dawgz » Wed Feb 27, 2008 11:45 pm
the main reason that i did not buy that ypipe, is because u'd have to hack into the mid pipe to put a Cat.
and in NJ, if u run with out a Cat and the trooper just happens to check to see if u have a cat or not, and if u dont, they will impound ur car.
So be carefull if u ever come into NJ.
Postby bigbirdSCed » Wed Feb 27, 2008 11:49 pm
oh i have a cat, we definatly had to hack the mid pipe down. im thinking a resonator will cut back on the raspieness but i may just redo the back end of the exhaust, ive always thought quad exhaust would look good with the TRD kit, plus 2 mufflers should quiet it down a bit.
bigbirdSCed
Postby Dawgz » Wed Feb 27, 2008 11:53 pm
theres no reason for that quad exhaust.
Postby bigbirdSCed » Wed Feb 27, 2008 11:58 pm
of course thers no reason, i just think it would look good. take some of the rice away from the giant muffler and tip. if it was a lara id love it but i just dont see the look fitting the car the way it is now. but this is just an idea, first step will be to install a resonator...or 4 :D
bigbirdSCed
Postby Dawgz » Thu Feb 28, 2008 12:12 am
are you comming on the 8th to the dyno?
by the way, adam has ur fuel upgrade setup, it looks pretty fckn sick with the Pressure reading.
Postby CASTRO » Thu Feb 28, 2008 12:17 am
sounds good
CASTRO
Postby Mr_Chunkz » Thu Feb 28, 2008 3:21 am
sounds alot more metallic and harsh than before
before was mellow and droned out
alot of ppl like that sound
alot dont
Im in between on it. Would sound mean blowin past me at WOT on the freeway tho
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby bigbirdSCed » Thu Feb 28, 2008 8:50 am
yeah ill be im pretty sure il be comming, i talked to king bout, figured hed told you.
the sound is growing especially at high rpms but the raspy sound and the fact thats its just TOO loud needsd to be fixed.
bigbirdSCed
Postby onefiend » Thu Feb 28, 2008 9:10 am
sounds better before the y-pipe...but the sound with it, isn't that bad. I've heard worst.
2007 Camry SE V6
onefiend
Postby SleeperSolara » Thu Feb 28, 2008 9:39 am
Nice project there.
Postby bigbirdSCed » Thu Feb 28, 2008 11:31 am
im taking it back to the shop tomarow and have them fix the small leak and weld in a resonator...a big one :D
bigbirdSCed
Postby Sp33d » Thu Feb 28, 2008 1:25 pm
i dont like the sound. i know that the sound coming from your vid is because of the better flow, hence better performance, but it sounds helllllllla ricey.
-Mark
Sp33d
