SolaraGuy.com • View topic - tranny hex bolt!!!!!!!!!!!!!!!!!
Postby DrakkkarDarkbladE » Mon Jan 16, 2006 12:28 pm
How in the world are you supposed to undo that f'in bolt? I have tried everything and it wont even budge even after spraying it with WD-40.
Refrain from using swear words.
2002 SLE V6
"Great minds discuss ideas; Average minds discuss events; Small minds discuss people." - Eleanor Roosevelt
DrakkkarDarkbladE
Postby SC V6 » Mon Jan 16, 2006 1:15 pm
Probably not a Hex bolt... probably a Torx head... which tranny bolt are you referring to?
SC V6
Postby DrakkkarDarkbladE » Mon Jan 16, 2006 2:09 pm
the one on the bottom of the pan that releases the oil....
2002 SLE V6
DrakkkarDarkbladE
Postby SleeperSolara » Mon Jan 16, 2006 2:57 pm
I think it is a 10mm or 12mm hex bolt socket.
If it don't come out you need to use a breaker bar, that will work.
Mine was kind-of hard, but i got it off though.
Postby bassthrive » Mon Jan 16, 2006 3:22 pm
An allen key and your hand just wont work. Definitely need a breaker bar.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby SC V6 » Mon Jan 16, 2006 4:55 pm
definitally thought you were talking about disassemblying a tranny... which is why I thought it was a torx.. anyway.. its an allen key... probably just tight because of the constant heating up and cooling of the tranny... just put some muscle into it, and make sure you going the right direction
SC V6
Postby DrakkkarDarkbladE » Tue Jan 17, 2006 12:17 pm
Got it off today finally. Leaked out about 4 quarts. Will do again in week then take down the pan in another week, and change the strainer and the gasket and its Royal Purple MAX ATF then.
2002 SLE V6
DrakkkarDarkbladE
