SolaraGuy.com • View topic - another SPARK PLUG QUESTION
Postby socalisolara » Tue Jun 13, 2006 3:22 am
i know people asked this before, but today i was told that i can use regular ngk spark plugs on our 1 gen solara's. is this true?? i am in need of changing my plugs and i am getting mixed information regards to spark plugs. and also how do you know when to change the spark plug wires?
socalisolara
Postby NeFaRiOuS_SLE » Tue Jun 13, 2006 3:45 am
It's typically every 60,000 miles, or whenever they're dirty, but the time to change it varies on what type you get (e.g. single-prong > dual-prong > iridium). As for NGK, it's what the dealer uses. I don't know about I4's, but V6 typically needs a dual prong.
Postby DrakkkarDarkbladE » Tue Jun 20, 2006 6:09 am
I went to the dealer yersterday actually. I told them that I need spark plugs for a 2002 Solara 1MZ-FE.
They gave me iridium sparkplugs with one prong on them. Each one was $10.32 plus tax.
2002 SLE V6
"Great minds discuss ideas; Average minds discuss events; Small minds discuss people." - Eleanor Roosevelt
DrakkkarDarkbladE
Postby Jon11582 » Tue Jun 20, 2006 7:21 am
Multiple prongs are for longer life. (if one prong gets eaten away, it uses the other, closer prong. Only one prong is in use at a time). They are not required, nor is there any other benefit.
My stocks on Gen1 5S are NGK platinum plugs. I changed to IK20s (Denso Iridium) at 60K
You can use Platinum or Iridium, and recommended brands are NGK and Denso.
Im not aware if plug wire replacement is a regular maintenance item, but they're not on my list. If anyone knows better, post it.
2000 Black Solara SE
Jon11582
Postby solarasweetie » Tue Jun 20, 2006 10:52 am
i had my car serviced about 9 months ago. and. it was a reg oil/filter, rad. flush, fuel system... and by the end of it all... the car wouldnt start. it needed the dual prong plugs... which i had to wait another hour for the delivery guy to get to the shop.
he brought me out to where my car was and cranked the motor... it wouldnt even start with the single prong plugs in it.
<b>rock it 'cause its <i>stockkk...</i></b>....Image
solarasweetie
Postby Jai_Jai_Binks » Tue Jun 20, 2006 10:56 am
Any of you guys do seafoam?
I recommend after you seafoam...leave you existing plus for a week and thereafter replace them. I knew a celica guy who bough denso iridums who replaced the plugs first and then did the seafoam...and then needed to replace his plugs again. Just a FYI for those who don't know.
Postby solarasweetie » Tue Jun 20, 2006 11:23 am
Jai_Jai_Binks wrote:Any of you guys do seafoam?
seafoam??
well.... i'll leave the complicated stuff to the guys. :)
the only thing i can really do... is change my oil and a flat. :wink:
solarasweetie
Postby Midias » Tue Jun 20, 2006 12:20 pm
Sea foam kicks donkey, but it does tend to make plugs a bit dirty. Although I have found that with quality plugs they tend too clean themselves off without a problem.
And YES I actually typed Donkey
solarasweetie wrote:i had my car serviced about 9 months ago. and. it was a reg oil/filter, rad. flush, fuel system... and by the end of it all... the car wouldnt start. it needed the dual prong plugs... which i had to wait another hour for the delivery guy to get to the shop.
Odd I have no problem with NGK iridium IX single prong. The doubles only fire one prong at a time (the closest one) this way they wear slower than others.
DrakkkarDarkbladE wrote:I went to the dealer yersterday actually. I told them that I need spark plugs for a 2002 Solara 1MZ-FE.
Others may wat to try fleabay I got mine same thing for 34 shipped.
BTW those are factory installed for my dads Acura Cl-S
Postby JAYDEE23 » Tue Jun 20, 2006 2:01 pm
dont know if you have advance auto parts or similar but the ngk iridiums are $7.50 (SINGLE STYLE)
NO PROBLEMS here with the single type
JAYDEE23
Postby Midias » Tue Jun 20, 2006 3:34 pm
2001 TOYOTA SOLARA 3 V6 1MZ-FE FI DOHC
Spark Plug Part No. Stock No. Plug Gap
Standard BKR6ES-11 5553 0.044
V-Power BKR6EYA 2249 0.044
G-Power Platinum BKR6EGP 7092 0.044
Laser Platinum BKR6EKPB-11 * # 3452 0.044
Iridium IX BKR6EIX-11 3764 0.044
I have the iridium IX single tip
they are great plugs
