SolaraGuy.com • View topic - idle rpms are jumpy
idle rpms are jumpy
idle rpms are jumpy
Postby bash0 » Sat Nov 01, 2003 9:32 pm
I recently purchased my solara with 75,000 miles and the engine is now starting to act up at idle. Last night was the worst when the engine would start at 800rpm drop to 600, back to 800, drop to 500 almost killing it and then jumping back to 800-1000. This cycle repeated about 5 times before I turned her off. I have also noticed the droping to 500 and kicking back up to normal idle rpms while out and about and stopped at a light. Is this simply a timing issue that will be resolved when i replace the timing belt, or do i have some serious issues to reckon with?
-bash0
bash0
Postby HKSV6SLE » Sun Nov 02, 2003 1:10 am
hey my car does that too....at least your car doesnt stop mine does everynow and than...
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby chef solara » Sun Nov 02, 2003 5:54 am
Hey mine did do that,
It all started after I put a new pulley on my S/C, I thought it was 6 but I think it was really 7.5psi. I measured the pulley and it was only 3 inches wide.
Any way after i put the pulley on the rpms would go all over the place just like you said.
One time I was sitting at a red light moving my wheels side to side and my car just stalled on me.
Later down the road , I had a cracked piston and a compression leak in another cyclinder.
I think the company that I bought the pulley from sent me the wrong one.
Pully boys .com Realy nice people but wrong pulley , Car go BOOM.
I have my boost gauge hooked up but not through the S/C , so w/ 4 psi on the gauge reads 2.5 maxpsi and when I had the 6 psi ( well I thought it was a 6) the gauge would read 6.
So my question was why would it read 6 witha 6 but 2.5 with a 4 ?
My answer is I had the wrong pully on there.
chef solara
Postby Mole » Sun Nov 02, 2003 12:00 pm
for normal start up, i do not understand why it would bounce from 800 to 600 rpm. did you install something to disrupt the ecu process?
as for chef, the reason why your car died was b/c of that pulley. did you reset the ecu after the install of the new pulley?
Postby TadS » Sun Nov 02, 2003 12:16 pm
Look at your air / fuel system. Are all the filters clean? Also, has it been tuned up yet? If you bought it at 75k, do you know if the 60k maintenance was done? Which motor do you have?
I have a bit of a wandering idle in my car also, but I am pretty sure it’s an air / fuel thing. Because it started after I got my throttle body back from the machine shop :angel: .
Might want to clean your idle sensor too. I had a link on how to do this, I’ll look around for it later.
TadS
Postby bash0 » Sun Nov 02, 2003 11:09 pm
TadS wrote:Look at your air / fuel system. Are all the filters clean? Also, has it been tuned up yet? If you bought it at 75k, do you know if the 60k maintenance was done? Which motor do you have?
Mine is the V6, no tune up that I know of, and what should have been done at 60k?
bash0
Postby TadS » Sun Nov 02, 2003 11:37 pm
bash0 wrote:Mine is the V6, no tune up that I know of, and what should have been done at 60k?
The 60,000-mile maintenance includes everything pretty much (Plugs, Filters, Valve Clearance, Fluids etc.)
I would take a look at your plugs, and see if your air filter is really dirty. If the plugs are toast, or the filter is clogged then it probably wasn't done. You can check these things for free, and are listed as causes of what your describing in the Haynes manual :).
There are some other things too, but those are things your dealer would probably need to test, worn camshaft lobes, leaking EGRs, and some of the other things Haynes list are a little to involved for me to mess with at least. The timing belt is on the Haynes trouble-shooting list also for erratic idle, so maybe you'll get lucky and that's all it is :).
TadS
Postby krzyray » Tue Nov 04, 2003 7:57 pm
I had the same exact problem... You need to clean your throtte body with some carb cleaner. After I did this, I got no more weird idling. Check this link on how to clean your throttle body: http://www.4x4wire.com/toyota/maintenan ... ttle_body/
enjoy!
I wish someone told me this info above when I was having the same problem :D
krzyray
Postby SolDoubt » Wed Nov 05, 2003 4:55 pm
hmm it says for a 3.0L wat about us with a 4 banger....same thing ya think?
SolDoubt
Postby TadS » Wed Nov 05, 2003 5:04 pm
A motor is a motor. The same basic ideas apply. Our throttle body is slightly different in shape (I think), but giving it a good cleaning won't hurt anything :D. My Toyota dealer offers a throttle body cleaning as part of the 60k service package.
TadS
Postby rapsux2001 » Fri Nov 07, 2003 2:04 pm
Maybe it's your Idle Air Control Valve. Camrys have this problem often. It's expensive too, it cost me $380 at Toyota.
rapsux2001
Postby SolaraT » Sat Nov 08, 2003 10:38 pm
krzyray wrote:I had the same exact problem... You need to clean your throtte body with some carb cleaner. After I did this, I got no more weird idling. Check this link on how to clean your throttle body: http://www.4x4wire.com/toyota/maintenan ... ttle_body/
enjoy!
You mean Fuel Injector Cleaner. No more carborators this day in age. :lol: I dido these comments.
SolaraT
Solaraguy need mo power guy
Postby adam2562 » Mon Nov 10, 2003 9:15 pm
i work at toyota... if is doing what mine does and it happens more in the mornings.. then its a leaky injector or maybe a few... i had a mechanic look at that for me... and i hev injectors asside ready when i have a new built 1MZ-FE put into my car
Adam - 99 V6 5spd 165k -SOLD
adam2562
