SolaraGuy.com • View topic - remote start on a manual
Postby hari-bhari » Wed Feb 02, 2005 3:57 pm
i ran a search and saw a lot of topics on remote start, but i dont think anyone has done it on a manual. i saw a kit on ebay with an immobilizer bypass for not too expensive, i dont want anything fancy, jus a remote with a good range that can start the car for me. when i emailed the seller to ask about the MT, he replied
There is a wire on the unit that grounds when the car
is about to start. You hook that up tp a relay that
will send either (-) or (+) signal to the clutch
over-ride switch to make it think it's depressed.
does this make sense to everyone, should i do this? oh and btw, i never leave the car in gear when i park it, i know this is a danger with having a remote start on a manual, but im willing to risk it 8)
hari-bhari
Postby all_red » Wed Feb 02, 2005 4:02 pm
I know couple of guys that have it, not on a Solara though. It was for about $200 and both have manual tranny. The starter will check to see if the car is in gear or not, I don't know how that is done, but I've seen it not working when the car is in gear. If its not, then the car would start, I guess it bypasses the cluch.
I wanted to do so, but didn't have that extra $200.
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby hari-bhari » Wed Feb 02, 2005 4:07 pm
the one i found on ebay is closer to about 40 bucks, like i said, no fancy features, just some electronics. i can do a self install with the help of a friend. hes got like 99.7% positive feedback
hari-bhari
Postby SC V6 » Wed Feb 02, 2005 4:31 pm
I've got it on my car... but then again, the car thinks it still has an auto in it
SC V6
Postby hari-bhari » Wed Feb 02, 2005 4:56 pm
SC V6 wrote:I've got it on my car... but then again, the car thinks it still has an auto in it
lolololol :lol: :lol: :lol:
hari-bhari
Postby DatSRBoi » Wed Feb 02, 2005 8:32 pm
Lucky...I TRIED to do it to my car and no much of a help from anyone. My car autostart still doesnt work and I have no dandy idea why. The negavtive thing I hooked it to that wire located on the E-brake. So Im sure I got that right. Everything else is done correctly. Now the part that I think im still doing wrong is the ignition crappers...Can anyone explain what option of the alarm wire goes with what color on the ignition? Like Starter goes to red on ignition etc......I been waiting soooo long haha no one ever helped me on my last forum.
Postby Fresco Bob » Fri Feb 04, 2005 1:42 pm
i dont know if this is applicable, but on my buddies gen1 teg you can start the car without the clutch only in first gear, i dont know if you would be able to rig that up yourself tho
Fresco Bob
Postby TRD_solaRa » Sun Feb 06, 2005 6:28 pm
Yea the motor definitely "bypasses" the clutch on manual cars . . . it is ILLEGAL to have on manual cars though, due to the liability of the car moving forward if it is in gear. A few of my friends have it and I think it is fricken sick! If you guys have a crappy alarm or don't have one . . . I would definitely recommend it. It costs roughly the same as a good car alarm anyways. Try Viper.
TRD_solaRa
Postby Jeremy1210 » Sat Feb 19, 2005 12:28 pm
I put a remote start on my maual celica. Works like a charm Just don't leave it in gear, if you do, then make sure you have the e_brake on b/c the car will move if its in gear. Just had to bypass the clutch sensor by putting the wires together.
Jeremy1210
Postby Solorange » Sat Feb 19, 2005 5:39 pm
Sorry for the change in subject, but do any SLE's come with manual stock?
Postby krook » Sat Feb 19, 2005 7:45 pm
DatSRBoi wrote:Lucky...I TRIED to do it to my car and no much of a help from anyone. My car autostart still doesnt work and I have no dandy idea why. The negavtive thing I hooked it to that wire located on the E-brake. So Im sure I got that right. Everything else is done correctly. Now the part that I think im still doing wrong is the ignition crappers...Can anyone explain what option of the alarm wire goes with what color on the ignition? Like Starter goes to red on ignition etc......I been waiting soooo long haha no one ever helped me on my last forum.
what brand do you have? also, you prolly have a transponder in your key so you'll have to get a bypass module that will send the signal to your ignition column. (DEI model 555U, or 555X)
A/T, or M/T??
ignition tap from the ALARM side is usually yellow. ignition wire IN THE VEHICLE is Black/Yellow in the ignition harness.
krook
