SolaraGuy.com • View topic - K&N drop-in filter...
Postby KRNguyW/aSOLARA » Sat Apr 30, 2005 12:26 am
Has anyone noticed any power gains/increased gas mileage from the K&N drop-in filters, on a stock or close to stock v6? I might wanna get one, but $50-60 aint cheap for me... Well, sorry if this ? has been asked, did a search and got craploads of results. thanks.
RED '99 SE V6 5-SPD--STOCK (at the moment)
KRNguyW/aSOLARA
Postby KRNguyW/aSOLARA » Sat Apr 30, 2005 12:34 am
WHOOAAA!! sorry, i tried search again...and well, i seemed to have overlooked.. sorry guys. delete?
KRNguyW/aSOLARA
Postby Dutch Master » Sat Apr 30, 2005 8:58 pm
Its shows a little difference...Kind of a more gain in throttle response if anything....I like it...I wont use the cheap paper sh!t anymore...
DM Records
myspace.com/dutchmasterrecords
Dutch Master
Postby Dawgz » Sun May 01, 2005 3:49 pm
I love it
Postby BradOwens » Sun May 01, 2005 5:52 pm
its a nice add on. i bought it awhile ago for $50. i love the sound it makes + a lil hp gain
BradOwens
Postby Dawgz » Sun May 01, 2005 7:12 pm
well the sound and the hp gain is very noticable...but i also took out the resonator..so that helped alot too..and sounds alot better also....this whole thing is gettn me really sooped for the s\c.... but yea so far its prolly the second best thing i baught for the car...
Postby hari-bhari » Sun May 01, 2005 10:57 pm
i agree. i had a CAI for a while, and then removed and sold it cuz i wasnt planning on doing anything else to the engine for a while. but then going back to stock sucked cuz i could feel the paper filter being so restrictive, and the acceleration was bogged down. then i installed the K&N filter (got it for only $10), and i must say i was thoroughly pleased with the difference it made. I would say about 70% of the power increase I felt with the CAI, I could feel with the filter (keep in mind, if you have an SC, the CAI will make a much bigger difference). I plan on taking the resonator off soon which should help a little more. My advice to all you guys out there, if your NA, you don't need a CAI. Save some $$ and stick with removing your resonator and getting the k&n filter. i agree it might not sound as deep or good as the true CAI, but performance wise, i think its about 80-90% as good, with less than 1/4 of the cost (if you get the filter brand new).
i know im bout to start a sh*tstorm in here, by the way, but im not tryin to hate, just giving an honest opinion from someone who's tried all the different options, so dont flame me
hari-bhari
Postby Fletch » Mon May 02, 2005 4:34 am
Stock air intake with resonators removed is not too bad. Should be able to find a K&N for $35 on the internet if you look.
2006 Legacy GT spec.B
Fletch
Postby SleeperSolara » Mon May 02, 2005 7:34 am
Yeah i have K&N air filter, wit out the snorkel in the fender, sounds like CAI.
And a better gain.
Postby Jackass-Jeff » Mon May 02, 2005 9:10 am
it's not a HUGE gain, but it's something. With the ram air intake (INJEN) you lose some torque and gain only HP.
The KN adds a little torque (1-2, lol) and a little hp...
And it starts to work better as it gets dirty... lol at first it'll feel like a ram air intake. After that, once it's broken in, you'll feel the torque!
1GR-FE ftw!
Jackass-Jeff
Postby Dutch Master » Mon May 02, 2005 10:03 am
Down with the CAI!
DM Records
Dutch Master
Postby lazyboyz69 » Mon May 02, 2005 12:40 pm
What about the TRD filter? TRD OR K&N... might be my next mod after the torque rod....
lazyboyz69
Postby methyl mike » Mon May 02, 2005 12:44 pm
Is it easy or hard to remove the resonator? Any instructions on how to do it?
methyl mike
Postby Dawgz » Mon May 02, 2005 1:13 pm
first u take off the screws for the driver side front wheel well, take the wheel well off, ull see a white Gallon looking thing (thats the resonator), just unbolt the two screws that hold it into place and remove it , drop it down and then remove it, cause the tire clearance wont let u move it twards u. and then u have a choice of either closing that port up or leaving i open like i did, i tried both ways, and i think leaving it open gives a better gain, then just put the wheel well back on and then screws back...done..ill take a pic of the resonator when i get back from work.
Postby KRNguyW/aSOLARA » Mon May 02, 2005 4:05 pm
so you cant have a aftermarket intake AND the k&n filter? I wanted to get a injen short ram, can i still get the k&n?
KRNguyW/aSOLARA
