SolaraGuy.com • View topic - Q for anyone with aftermarket flywheel/clutch
Postby methyl mike » Wed Dec 21, 2005 10:40 am
Ok, first off what clutch and/or flywheel do you have? Second, what difference have you noticed from switching from stock? ANy likes/dislikes? With the flywheel in particular, do you have to rev the engine more to get the car moving? Is your car any faster with a better clutch/lightened flywheel?
methyl mike
Postby jhenty » Wed Dec 21, 2005 2:53 pm
the clutch catches at a higher point so you dont need to push as far to change gears. It takes a little getting used to with the different catch area but its definetly a better feel. As for the flywheel I had my mechanic grind it down and balance it to just about as light as a fidenza. It revs a little quicker but its hard to make an accurate comparrision without a dyno or time slips as to how much better it performs.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby toy4x4boy » Wed Dec 21, 2005 3:23 pm
South Bend Rally series clutch, stock resurfaced flywheel. Clutch engages much quicker, feels stronger, pedal is much lighter than stock. I love it. Does take a little getting used to.
toy4x4boy
Postby hskrsolara » Wed Dec 21, 2005 10:50 pm
Fidanza flywheel with spec 2+ clutch. Definitely have to rev the engine more to avoid killing it on a restart. Clutch is super catchy. Definitely will take some getting used to. Overall, car revs much quicker and when I finally get it broke in, I know this thing is gonna hook up sweet! Overall, very solid setup.
hskrsolara
Postby dominoSLEV6 » Wed Dec 21, 2005 11:43 pm
While we're on topic, Question...
If I SC or spray my car, anything like that, will I have to upgrade my clutch?
Also, aside from a dead stop in 1st, how do the aftermarket clutches work out in between gears, namely 1st -2nd and 2nd-3rd. Does it just catch quicker so you have a lot less give with your timing?
I'm still on a stock clutch and probably will be for at least a little while as I'm not even over 80k. But when I put in a new one I'm definitely going to upgrade.
-chris
dominoSLEV6
Domino
Postby JMSinMaryland » Wed Dec 21, 2005 11:58 pm
For whatever stupid reason I have so many ideas whenever I see your new car. I would so go with a black and silver theme. I think shaving your emblems and switching out the front silver T with a black pearl emblem T would look HOT. Also rims like mine Image would look hot. Also those blacked out headlights with APC Titan Bulbs as well to keep the black/silver theme going. As I said I have so many ideas Im thinking in the future of picking up a 5S-FE Solara in black with a manual, dropping a built up 3S-GTE and 1MZ-FE manual tranny and dropping it on 20's (making it a weekend car). Maybe Im hoping you'll like my ideas and try it on your car and then I can see if it looks good for the future :wink: . Jon
JMSinMaryland
Postby methyl mike » Thu Dec 22, 2005 10:40 am
hskrsolara wrote:Fidanza flywheel with spec 2+ clutch. Definitely have to rev the engine more to avoid killing it on a restart. Clutch is super catchy. Definitely will take some getting used to. Overall, car revs much quicker and when I finally get it broke in, I know this thing is gonna hook up sweet! Overall, very solid setup.
So, youre basically youre saying you have to rev the engine more when moving from a dead stop? Is it a lot more? Any increase in acceleration?
methyl mike
