SolaraGuy.com • View topic - Where to order eibach camber kit?
Postby supamouse09 » Tue Apr 03, 2007 11:20 pm
as in the title im looking for a place to order the eibach camber kit. i have a local shop thats selling them 35 for the front and 35 for the rear. anybody know a place with better pricing in socal or a website thats better priced??
01 Toyota Solara SLE V6 Manual Swap
supamouse09
Postby orlin03 » Wed Apr 04, 2007 4:21 am
Tire rack sells a bit cheaper, but with shipping, it probably wouldn't be any better. 35 isn't bad at all.
orlin03
Postby RichD978 » Wed Apr 04, 2007 4:40 am
i thought we dont need them
RichD978
Postby akora12 » Wed Apr 04, 2007 5:57 am
RichD978 wrote:i thought we dont need them
ditto.
Postby SleeperSolara » Wed Apr 04, 2007 6:37 am
Sometimes you don't and sometimes you do need them....
For me example, i need them cause my camber is messed up on the driver front wheel, i hit a low curb while we had an ice storm and it messed up my driver front camber.
So wheneva i lower my car i'll be gettin' some camber bolts for my car.
Postby Mole » Wed Apr 04, 2007 7:22 am
i stand on not needing them...
Postby unbalancedwood » Wed Apr 04, 2007 8:03 am
Yeah, i think we dont need them either, although my shop tried to get me to buy them when they saw i was lowered. they wanted $57 for one bolt + $40 in labor, at least your shop isnt that bad.
Ebay has them for $29shipped for a kit though (front L&R)...
unbalancedwood
Postby rollaevo99 » Wed Apr 04, 2007 9:19 am
I don't know why, but I have cambers just the passenger side.
Postby Jai_Jai_Binks » Wed Apr 04, 2007 9:19 am
As a general rule of thumb, when installing...you don't need them. But if your alignment guy always has issues with your camber and your having issues with uneven tire-ware...then you will need it. Thus far, KNOCK on wood, i'm good..but its only a matter of time for me (and some of you all).
Postby funboy102 » Wed Apr 04, 2007 2:42 pm
^^^^ He said it best.... Some people don't need them, but some unfortunate people WILL need them. When you take your car in for an alignment, you will find out if you need them or not.
funboy102
Postby supamouse09 » Wed Apr 04, 2007 4:27 pm
yeah unfortunately i need them. i have uneven tire wear and my wheels butterfly a little bit. i think it is from the added weight of having a convertible but im not sure. well thanks for the input guys.
supamouse09
Postby funboy102 » Wed Apr 04, 2007 7:52 pm
Uneven tire wear can be attributed to a lot of things however. You must deduct each case before you conclude it's the camber. Did you know un-aligned toe will actually mess up your tires more? I heard that in-correct toe alignment will actually account for 70% of tire wear, camber is just about 20%, and improper air pressure the rest 10%. Make sure it's really the camber before you spend money on a camber kit.
funboy102
Postby Toy1mzfe » Wed Apr 04, 2007 8:28 pm
if u need em just get em. they are easy to install and easy to adjust, although i perfer it being laser-ed corrected.
i had crucial camber issue on my tib when i dropped it 2.5inch on ground controls. The cam bolts that goes in the struts are easily adjusted by turning the cam bolt.
and yes toe wear has more tire wear than camber..
having wheels pointed towards each other is a killer
/ \ top view looking dawn
Postby Jai_Jai_Binks » Thu Apr 05, 2007 9:11 am
supamouse09 wrote:yeah unfortunately i need them. i have uneven tire wear and my wheels butterfly a little bit.
I hear what your saying, but are you hearing what we're saying?? we can't decide whats causing this..we can only speculate. Your best bet would be to go get some life-time-alignment somewhere (i've got mine at firestone on a Wednesdays - ladies special for $129.99 - suckered my wifee to go in for this). There they will tell you whats causing your uneven tire ware.
Postby orlin03 » Thu Apr 05, 2007 2:54 pm
It's easy to check the camber yourself. Get a straight piece of board the lenght of the wheel diameter, tape a torpedo level to it (walmart sells these 9" levels for dirt cheap), pull straight into a reletively level area, and hold the board against the rim top-bottom. Idealy, the horizontal bubble should be just touching the outter line, indicating that the top of the tire is slightly closer to the car's centerline than the bottom. If it is your outside edge that is wearing, and the bubble is toward the inside, then you need a kit, or if it is the inside of your tire that is wearing, and the bubble leans excesively into or past the outside line, you need the kit. If the bubble looks good (slightly off-center), then maybe it is another factor. Most places will do a toe alignment no matter what, though; so if you're still wearing, it's because you need the kit. :P
orlin03
